メインコンテンツにスキップ
Jura Impressa S model front cover
必要な工具と部品
  1. Jura Impressa S model front cover, How to open a Jura Impressa S model cover: 手順 1、 2の画像 1 Jura Impressa S model front cover, How to open a Jura Impressa S model cover: 手順 1、 2の画像 2
    • Always remove the power cord from the wall outlet.
    • Lift out the coffee tray
    • Remove the lid sealing the coffee bean container
    • Remove all of the coffee beans you can possibly remove.
    • Pull the adjuster of the coffee bean grinder straight up
    • Remove the four T15 Torx screws
  2. Jura Impressa S model front cover: 手順 2、 2の画像 1 Jura Impressa S model front cover: 手順 2、 2の画像 2
    • Remove the cup heat plate.
    • It can be opened like a book.
    • Below the cup heat plate there are three more T15 Torx screws. Remove them.
  3. Jura Impressa S model front cover: 手順 3、 1の画像 1
    • The top cover is now free. Lift ´er up and set ´er aside.
  4. Jura Impressa S model front cover, Jura Impressa S model front cover: 手順 4、 2の画像 1 Jura Impressa S model front cover, Jura Impressa S model front cover: 手順 4、 2の画像 2
    • Remove the knob for the steam valve by simply pulling it off.
    • The front cover is secured with a Torx T15 screw. Remove it.
  5. Jura Impressa S model front cover: 手順 5、 1の画像 1
    • Now the front cover can be opened like a door for a few inches. The hinge is on the left.
  6. Jura Impressa S model front cover: 手順 6、 1の画像 1
    • Various hoses hinder the further opening of the front cover. You need to remove the steam valve keypad from the cover.
    • Use a spudger to lift the two notches at the top of the front cover a bit to release the keypad at the top.
    • Lift the keypad upwards and pull it to the back. The steam pipe will slide out from its connection.
    • All hoses can remain connected.
  7. Jura Impressa S model front cover: 手順 7、 1の画像 1
    • Remove the silicone hose leading from the steam valve to the coffee spout. If it is secured with a cable tie which must be removed first.
    • The front cover is now free and can be opened.
終わりに
To reassemble your device, follow these instructions in reverse order
以下の翻訳者の皆さんにお礼を申し上げます:
de en
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
作成者
1人の作成者と共同作成されました。
VauWeh
メンバー登録日: 10/19/15
203,382 ポイント
246のガイドは作成済み
チーム
Repair is War on Entropy Repair is War on Entropy人のメンバー
Community
25 メンバー
1,121のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 15
今までの合計 702
