はじめに
Your fully automatic coffee machine makes very loud noises when grinding the coffee beans?
When making coffee, does the coffee only come out in drips?
Then you may have a problem with the grinder of your Jura Impressa F50 fully automatic coffee machine.
These instructions are intended to help you get access to the grinder of your fully automatic coffee machine in order to service it or to replace it completely.
It consists of a total of 3 parts: opening the machine, removing the grinder and reassembly.
必要な工具と部品
Remove the drip pan, tray and container for used coffee,...
... the water tank, ...
and the aroma protection cover.
Remove the lock washer on the axle for grinding degree adjustment using pliers.
6 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
