メインコンテンツにスキップ
Jura Capresso IMPRESSA J5 Magnetic Drainage Valve
必要な工具と部品
  1. Jura Capresso IMPRESSA J5 Magnetic Drainage Valve, Jura Capresso IMPRESSA J5  opening procedure: 手順 1、 1の画像 1
    • Unplug the power cord!
    • Remove the water tank and the drip tray. Remove all coffee beans from the storage container.
  2. Jura Capresso IMPRESSA J5 Magnetic Drainage Valve: 手順 2、 3の画像 1 Jura Capresso IMPRESSA J5 Magnetic Drainage Valve: 手順 2、 3の画像 2 Jura Capresso IMPRESSA J5 Magnetic Drainage Valve: 手順 2、 3の画像 3
    • Flip open the lid of the bean compartment.
    • Unscrew the two slotted screws inside the bean compartment. The screws have a rubber washer and will not come out completely.
    • Remove the bean compartment.
  3. Jura Capresso IMPRESSA J5 Magnetic Drainage Valve: 手順 3、 3の画像 1 Jura Capresso IMPRESSA J5 Magnetic Drainage Valve: 手順 3、 3の画像 2 Jura Capresso IMPRESSA J5 Magnetic Drainage Valve: 手順 3、 3の画像 3
    この手順で使用する道具:
    iFixit Precision 4 mm Screwdriver Bit
    $2.99
    購入する
    • The top cover is fastened with oval head screws. Unscrew them.
    • These screws have an oval head that makes them look like rivets (picture 2). You need to use a special bit - also available at iFixit - for their removal. Here a DIY guide. If the right bit is not available, it could be done with a pair of needle nose pliers. Jura wants to keep us out of our own machines!!!
  4. Jura Capresso IMPRESSA J5 Magnetic Drainage Valve: 手順 4、 1の画像 1
    • Also remove the two oval head screws underneath the ground coffee compartment lid.
  5. Jura Capresso IMPRESSA J5 Magnetic Drainage Valve: 手順 5、 1の画像 1
    • Now you can pry up the top cover all around.
    • Remove the top cover. This often requires a little force.
    • Use plastic tools to avoid scratching your device.
  6. Jura Capresso IMPRESSA J5 Magnetic Drainage Valve: 手順 6、 2の画像 1 Jura Capresso IMPRESSA J5 Magnetic Drainage Valve: 手順 6、 2の画像 2
    • Turn the device with the back facing you.
    • Turn the Jura label a few degrees counterclockwise. If it's hard to do, use a small suction cup.
    • Remove the Jura label.
  7. Jura Capresso IMPRESSA J5 Magnetic Drainage Valve: 手順 7、 3の画像 1 Jura Capresso IMPRESSA J5 Magnetic Drainage Valve: 手順 7、 3の画像 2 Jura Capresso IMPRESSA J5 Magnetic Drainage Valve: 手順 7、 3の画像 3
    • Underneath the label you will find two Torx T15 screws. Remove them.
    • Carefully pull the top of the chrome cover slightly outwards, then push it down and put it aside.
  8. Jura Capresso IMPRESSA J5 Magnetic Drainage Valve: 手順 8、 1の画像 1
    • Remove the Torx T15 screw on the side panel with the water tank.
  9. Jura Capresso IMPRESSA J5 Magnetic Drainage Valve: 手順 9、 2の画像 1 Jura Capresso IMPRESSA J5 Magnetic Drainage Valve: 手順 9、 2の画像 2
    • Pull the right side panel slightly towards the back.
    • Remove the side panel.
  10. Jura Capresso IMPRESSA J5 Magnetic Drainage Valve: 手順 10、 1の画像 1
    • Pull the left side panel slightly towards the back and remove it.
  11. Jura Capresso IMPRESSA J5 Magnetic Drainage Valve, Jura J5 Magnetic Drainage Valve: 手順 11、 1の画像 1
    • The motor for the drainage valve is located in the lower side of the unit near the center. It is fastened with three screws and connected with several flat plugs. In the picture, the ceramic valve has already been pushed off.
    • Note: models from J6 onwards have a motor installed and not a magnet.
  12. Jura Capresso IMPRESSA J5 Magnetic Drainage Valve: 手順 12、 3の画像 1 Jura Capresso IMPRESSA J5 Magnetic Drainage Valve: 手順 12、 3の画像 2 Jura Capresso IMPRESSA J5 Magnetic Drainage Valve: 手順 12、 3の画像 3
    • Unscrew the three Torx T15 screws on the motor for the drain valve. Pay attention to the washers underneath.
    • Carefully pull out the motor.
    • If you want to replace it, you still have to disconnect the flat connectors. Note where the connectors are connected.
終わりに
Work through the steps in reverse order to reassemble your device.
2 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
de en
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
作成者
1人の作成者と共同作成されました。
VauWeh
メンバー登録日: 10/19/15
201,734 ポイント
246のガイドは作成済み
チーム
Repair is War on Entropy Repair is War on Entropy人のメンバー
Community
25 メンバー
1,097のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 42
今までの合計 859
