メインコンテンツにスキップ
Jumper Angelsounds JPD-100S The Transducer Replacement
必要な工具と部品
  1. Jumper Angelsounds JPD-100S The Transducer  Replacement, Motherboard: 手順 1、 1の画像 1
    • Access the battery compartment
    • Remove the battery compartment lid and set it aside.
    • Disconnect the battery and set it aside.
  2. Jumper Angelsounds JPD-100S The Transducer  Replacement: 手順 2、 2の画像 1 Jumper Angelsounds JPD-100S The Transducer  Replacement: 手順 2、 2の画像 2
    • Puncture the sticker in the battery compartment with a spudger to access the screw beneath it.
  3. Jumper Angelsounds JPD-100S The Transducer  Replacement: 手順 3、 1の画像 1
    • Remove the 7mm Phillips #1 screw from the battery compartment.
    • Place the screw in a secure place.
  4. Jumper Angelsounds JPD-100S The Transducer  Replacement: 手順 4、 2の画像 1 Jumper Angelsounds JPD-100S The Transducer  Replacement: 手順 4、 2の画像 2
    • Begin prying open the device.
    • Insert a plastic opening tool into the side groove about 2cm from the pink plastic component and pry open one side of the device.
    • Once the side is separated, leave the opening tool inside to prevent the two sides from closing.
  5. Jumper Angelsounds JPD-100S The Transducer  Replacement: 手順 5、 2の画像 1 Jumper Angelsounds JPD-100S The Transducer  Replacement: 手順 5、 2の画像 2
    • Insert another plastic opening tool into the groove opposite to the side of the tool already inserted.
    • Create separation on that side until the white plastic component comes off entirely.
    • Place the white plastic component in a secure place.
  6. Jumper Angelsounds JPD-100S The Transducer  Replacement: 手順 6、 1の画像 1
    • With your hand, remove the pink component.
  7. Jumper Angelsounds JPD-100S The Transducer  Replacement: 手順 7、 1の画像 1
    • Remove the 7mm Phillips #1 screw in the middle of the motherboard.
  8. Jumper Angelsounds JPD-100S The Transducer  Replacement, The Transducer: 手順 8、 1の画像 1
    • Unsolder the Black cable
  9. Jumper Angelsounds JPD-100S The Transducer  Replacement: 手順 9、 2の画像 1 Jumper Angelsounds JPD-100S The Transducer  Replacement: 手順 9、 2の画像 2
    • Unsolder the red cables from the metal plates.
終わりに
作成者
1人の作成者と共同作成されました。
Muosa Almubarak
メンバー登録日: 09/29/15
101 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 6-1, Remmell Fall 2015 USF Tampa, Team 6-1, Remmell Fall 2015人のメンバー
USFT-REMMELL-F15S6G1
6 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 11
今までの合計 320
