メインコンテンツにスキップ
Joy-Con ZL Switch Replacement
必要な工具と部品
  1. Joy-Con ZL Switch Replacement, Unscrew the back cover: 手順 1、 1の画像 1
    • Using the Y00 Tri-Point screwdriver, remove four M1.4 x 5mm screws to loosen the hard plastic back of the Joy-Con.
    • After the screws are removed, lift the cover to reveal the inside of the Joy-Con and locate the ZL button.
    • The button exposed could either be the ZL or the ZR depending on which Joy-Con needs to be fixed.
  2. この手順で使用する道具:
    • Use tweezers to lift the ZL button a little then pull upwards to get it back into place.
    • Once the button is back in place, place the hard cover back on the Joy-Con and screw it back on.
    • Click the button a couple times to ensure that it's back in place and working.
    • This may either be the ZL or ZR button depending on the Joy-Con being fixed.
  3. Joy-Con ZL Switch Replacement: 手順 5、 1の画像 1
    • Resume gameplay!
  4. Joy-Con ZL Switch Replacement, The problem part: 手順 6、 2の画像 1 Joy-Con ZL Switch Replacement, The problem part: 手順 6、 2の画像 2
    • This tiny piece of metal had come off the small pcb and ribbon cable. In doing so it had jammed the switch.
    • Use the guide for un-jamming ZL switch, to remove the case screws, the top cover and the ZL switch and springs.
  5. Joy-Con ZL Switch Replacement, Splitting it apart: 手順 7、 3の画像 1 Joy-Con ZL Switch Replacement, Splitting it apart: 手順 7、 3の画像 2 Joy-Con ZL Switch Replacement, Splitting it apart: 手順 7、 3の画像 3
    • Having removed the plastic button and 2 springs you uncover the switch and holding screw.
    • Remove the holding screw.
  6. Joy-Con ZL Switch Replacement, Pop out the battery: 手順 8、 2の画像 1 Joy-Con ZL Switch Replacement, Pop out the battery: 手順 8、 2の画像 2
    • Lift the battery out of the battery chassis tray.Use a plastic splitter if necessary.
    • Do not remove the sticky tape underneath as this is unnecessary. It does not effect the repair.
  7. Joy-Con ZL Switch Replacement, Remove the battery tray: 手順 9、 2の画像 1 Joy-Con ZL Switch Replacement, Remove the battery tray: 手順 9、 2の画像 2
    • Remove the 4 screws holding down the inner battery support chassis. This exposes the switch connector to the pcb.
    • Note the bottom left screw in this picture is shorter than the others and needs to be put back in the correct aperture.
  8. Joy-Con ZL Switch Replacement, Pulling the plug on the problem....: 手順 10、 1の画像 1
    この手順で使用する道具:
    • Gently pull on the ribbon cable to remove the plug from the socket.
    • Insert plug on new ribbon cable & switch.
    • You may need to push in the plug with plastic tweezers. Take care not to damage the cable.
  9. Joy-Con ZL Switch Replacement, Putting it back together: 手順 11、 1の画像 1
    • Replace batters chassis tray and screw back into place. Note to put back the shorter screw into the correct hole.
    • Fold battery back into place. Gently push down to get the battery stuck back to the tape.
    • Adjust the ribbon cable to ensure it is not trapped. Place the switch over the alignment pin and screw down the retaining screw.
  10. Joy-Con ZL Switch Replacement, Yippee it works!: 手順 12、 3の画像 1 Joy-Con ZL Switch Replacement, Yippee it works!: 手順 12、 3の画像 2 Joy-Con ZL Switch Replacement, Yippee it works!: 手順 12、 3の画像 3
    • Put the two springs back on their retaining pins and push the button back into place.
    • It should click into place and when you push on the button you should hear the switch click.
    • Fold the cover back over and check there are no trapped wires before screwing back the 4 screws on the cover to complete the repair.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Robin Razzell
メンバー登録日: 09/04/13
340 ポイント
2のガイドは作成済み
1件のガイドコメント
This doesn’t really cover the removal of the ZL/ZR Buttons.
It is good for removing the actual button on the mother board, but not for removing the plastic button on the remote.
OreoDestroyer93 - 返信
コメントを追加
統計データ:
過去 24時間: 11
過去 7 日: 86
過去 30 日: 333
今までの合計 11,767
