メインコンテンツにスキップ
Jazz UltraTab C855 Battery Replacement
必要な工具と部品
  1. Jazz UltraTab C855 Battery Replacement, Back Cover: 手順 1、 1の画像 1
  2. Jazz UltraTab C855 Battery Replacement: 手順 2、 1の画像 1
    • Pry the back case off using the blue Plastic Opening Tools. Work one along the seem until you can get your fingers under to pull it apart.
  3. Jazz UltraTab C855 Battery Replacement, Battery: 手順 3、 1の画像 1
    • Remove the yellow tape from the sides of the battery, and the surrounding components.
  4. Jazz UltraTab C855 Battery Replacement: 手順 4、 1の画像 1
    • Cut the pos(+) and neg (-) wires that connect the battery to the device using wire cutters.
    • Cut the wires towards the middle. During installation of your new battery these wires will be stripped back and soldered or crimped to reattach.
  5. Jazz UltraTab C855 Battery Replacement: 手順 5、 1の画像 1
    • Using a plastic opening tool or spudger, slowly pry the battery away from the board.
    • The battery is secured to the device with adhesive.
    • Metal spudgers can puncture an unprotected battery, potentially causing a fire. When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
  6. Jazz UltraTab C855 Battery Replacement: 手順 6、 1の画像 1
    • Use a two sided adhesive to secure the new battery in place.
    • Solder or crimp the wires back together to reattach to the motherboard.
    • Replace any yellow tape that you removed at the beginning to secure the wires back in place.
終わりに
作成者
2人の作成者と共同で作成されました。
Cory Hodge
メンバー登録日: 09/14/15
201 ポイント
2のガイドは作成済み
チーム
IUPUI, Team 1-3, Baechle Fall 2015 IUPUI, Team 1-3, Baechle Fall 2015人のメンバー
IUPUI-BAECHLE-F15S1G3
5 メンバー
10のガイドは作成済み
コメント 1 件
Very good instructions.....but where do I buy the repkacement battery from?
fremontmyers - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 565
