はじめに
If your Jazz HDV178 Camcorder will not turn on, has an unresponsive screen, or will not charge, the motherboard for this device may require repair or replacement.
This guide will provide a step by step process to repair or replace the motherboard of the Jazz HDV178 Camcorder. This process will require the removal of the battery, lens, and other housing components in order to complete. There are no special skills required to complete this task. It is important to keep track of each screw as this process requires the removal of many.
必要な工具と部品
Press down on the grooved plastic with your thumbs.
Push the back cover in the direction indicated by the small arrow on the grooved plastic. The back cover should slide right off.
Once you have the back cover off, the camcorder should look like this.
Look on the battery for a model number to assure that you acquire the correct replacement part.
The camcorder model number is located in the red box. Verify that you have a Jazz HDV178.
Remove the camera mount by unscrewing the 4.5 mm screw in the hole.
This is the bottom of the camcorder near where the wrist strap connects.
Use tweezers to remove the rubber button assembly.
Blow on the sensors underneath to remove any dust on the sensors.
ある他の人がこのガイドを完成しました。
