メインコンテンツにスキップ
Jazz Digi-Stix JDC11 Board/Microphone/Battery Compartment Replacement
必要な工具と部品
  1. Jazz Digi-Stix JDC11 Board/Microphone/Battery Compartment Replacement, Battery: 手順 1、 2の画像 1 Jazz Digi-Stix JDC11 Board/Microphone/Battery Compartment Replacement, Battery: 手順 1、 2の画像 2
    • Flip the device so that the bottom is facing upwards. Using thumb, push the tab on the bottom in the direction indicated by the arrow and then lift the unhinged part of the tab.
  2. Jazz Digi-Stix JDC11 Board/Microphone/Battery Compartment Replacement: 手順 2、 1の画像 1
    • Tilt device so that batteries slide out.
  3. Jazz Digi-Stix JDC11 Board/Microphone/Battery Compartment Replacement, Lens: 手順 3、 3の画像 1 Jazz Digi-Stix JDC11 Board/Microphone/Battery Compartment Replacement, Lens: 手順 3、 3の画像 2 Jazz Digi-Stix JDC11 Board/Microphone/Battery Compartment Replacement, Lens: 手順 3、 3の画像 3
    • Carefully insert the flat end of the spudger into the seam on the top side of the device. Carefully twist the spudger to open the device. Repeat this step at incremental locations around the seam of the device until the two case halves separate.
    • Before completely separating the two halves, separate the case from the battery compartment cover, pulling the case apart. Take care not to break the plastic hinge as the battery compartment cover is removed.
  4. Jazz Digi-Stix JDC11 Board/Microphone/Battery Compartment Replacement: 手順 4、 3の画像 1 Jazz Digi-Stix JDC11 Board/Microphone/Battery Compartment Replacement: 手順 4、 3の画像 2 Jazz Digi-Stix JDC11 Board/Microphone/Battery Compartment Replacement: 手順 4、 3の画像 3
    • Make sure to take care in prying case apart. There are two wires (one red and one black) that could get disconnected from the motherboard.
    • Gently seperate the two halves of the device.
    • To remove the circuit board from the right section of the device, unscrew the two 5.6 mm Phillips #00 screws.
    • When the screws have been fully unscrewed, use the tweezers to remove them from the device.
  5. Jazz Digi-Stix JDC11 Board/Microphone/Battery Compartment Replacement: 手順 5、 3の画像 1 Jazz Digi-Stix JDC11 Board/Microphone/Battery Compartment Replacement: 手順 5、 3の画像 2 Jazz Digi-Stix JDC11 Board/Microphone/Battery Compartment Replacement: 手順 5、 3の画像 3
    • Turn the device over so that the lens is facing downward. Take care not to detach any wires during this step.
    • Locate and unscrew the two 5.6 mm Phillips #00 screws holding the lens to the board.
    • Turn the device back over so that the lens faces upward, and carefully remove the lens from the board.
  6. Jazz Digi-Stix JDC11 Board/Microphone/Battery Compartment Replacement, Board/Microphone/Battery Compartment: 手順 6、 3の画像 1 Jazz Digi-Stix JDC11 Board/Microphone/Battery Compartment Replacement, Board/Microphone/Battery Compartment: 手順 6、 3の画像 2 Jazz Digi-Stix JDC11 Board/Microphone/Battery Compartment Replacement, Board/Microphone/Battery Compartment: 手順 6、 3の画像 3
    • To remove the microphone from the case, insert the tip of the spudger under the microphone's edge and pry it away from the case.
  7. Jazz Digi-Stix JDC11 Board/Microphone/Battery Compartment Replacement: 手順 7、 3の画像 1 Jazz Digi-Stix JDC11 Board/Microphone/Battery Compartment Replacement: 手順 7、 3の画像 2 Jazz Digi-Stix JDC11 Board/Microphone/Battery Compartment Replacement: 手順 7、 3の画像 3
    • Unscrew the three 5.6 mm Phillips #00 screws that connect the battery compartment to the case.
    • Remove the battery compartment from the case of the device.
終わりに
作成者
4人の作成者と共同で作成されました。
Katelyn Fry
メンバー登録日: 03/11/13
1 ポイント
7のガイドは作成済み
チーム
Clemson, Team 12-3, Benson Spring 2013 Clemson, Team 12-3, Benson Spring 2013人のメンバー
CLEM-BENSON-S13S12G3
3 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 300
