はじめに
The battery will be replaced by dismantling the device, disconnecting the current battery and connecting a new battery.
必要な工具と部品
Expose the motherboard and battery and place in a position that will be easy to access and work with.
Use tweezers to remove the battery's wire from the motherboard at the connection point.
Pull the battery from the motherboard.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
