メインコンテンツにスキップ
JVC KW-V820BT Driver Side Panel Removal and Replacement
必要な工具と部品
  1. JVC KW-V820BT Driver Side Panel Removal and Replacement, Front Panel Assembly: 手順 1、 3の画像 1 JVC KW-V820BT Driver Side Panel Removal and Replacement, Front Panel Assembly: 手順 1、 3の画像 2 JVC KW-V820BT Driver Side Panel Removal and Replacement, Front Panel Assembly: 手順 1、 3の画像 3
    • Remove the four 1/8-inch black machine screws using a Phillips #00 screwdriver.
  2. JVC KW-V820BT Driver Side Panel Removal and Replacement: 手順 2、 2の画像 1 JVC KW-V820BT Driver Side Panel Removal and Replacement: 手順 2、 2の画像 2
    • Remove three steel-finish, pan-head, 1/64 x 3/16" machine screws identified in the photograph, using the Phillips #0 screwdriver.
  3. JVC KW-V820BT Driver Side Panel Removal and Replacement: 手順 3、 3の画像 1 JVC KW-V820BT Driver Side Panel Removal and Replacement: 手順 3、 3の画像 2 JVC KW-V820BT Driver Side Panel Removal and Replacement: 手順 3、 3の画像 3
    • Using your fingers and/or a metal spudger, gently release the plastic locking tabs of the front panel assembly from the steel enclosure while prying the front panel assembly away from the steel enclosure with your fingers.
  4. JVC KW-V820BT Driver Side Panel Removal and Replacement: 手順 4、 1の画像 1
    • Gently remove the front panel from the steel enclosure.
  5. JVC KW-V820BT Driver Side Panel Removal and Replacement: 手順 5、 3の画像 1 JVC KW-V820BT Driver Side Panel Removal and Replacement: 手順 5、 3の画像 2 JVC KW-V820BT Driver Side Panel Removal and Replacement: 手順 5、 3の画像 3
    • Gently separate the ribbon cable from from ZIF connector on the circuit board using a metal smudger.
    • Be careful not to scratch or damage components or features of the circuit board with the metal spudger
  6. JVC KW-V820BT Driver Side Panel Removal and Replacement, Top Panel Removal: 手順 6、 3の画像 1 JVC KW-V820BT Driver Side Panel Removal and Replacement, Top Panel Removal: 手順 6、 3の画像 2 JVC KW-V820BT Driver Side Panel Removal and Replacement, Top Panel Removal: 手順 6、 3の画像 3
    • Remove seven 1/64 x 3/16" screws from the top panel using the Phillips #0 screwdriver.
    • Remove the top panel.
  7. JVC KW-V820BT Driver Side Panel Removal and Replacement, Disc Drive: 手順 7、 1の画像 1
    • After removing all screws and top panel, lift up disc drive from steel enclosure.
  8. JVC KW-V820BT Driver Side Panel Removal and Replacement: 手順 8、 1の画像 1
    • Turn over the disc drive to expose the connector.
    • Gently remove the ribbon cable from the ZIF on the circuit board using the metal spudger.
  9. JVC KW-V820BT Driver Side Panel Removal and Replacement: 手順 9、 3の画像 1 JVC KW-V820BT Driver Side Panel Removal and Replacement: 手順 9、 3の画像 2 JVC KW-V820BT Driver Side Panel Removal and Replacement: 手順 9、 3の画像 3
    • Gently pull to remove the electrical connector from disc drive.
  10. JVC KW-V820BT Driver Side Panel Removal and Replacement: 手順 10、 2の画像 1 JVC KW-V820BT Driver Side Panel Removal and Replacement: 手順 10、 2の画像 2
    • Remove 2 pan-head, 1/64 x 3/16" machine screws using a Phillips #0 screwdriver.
  11. JVC KW-V820BT Driver Side Panel Removal and Replacement: 手順 11、 2の画像 1 JVC KW-V820BT Driver Side Panel Removal and Replacement: 手順 11、 2の画像 2
  12. JVC KW-V820BT Driver Side Panel Removal and Replacement, Driver Side Panel Removal and: 手順 12、 3の画像 1 JVC KW-V820BT Driver Side Panel Removal and Replacement, Driver Side Panel Removal and: 手順 12、 3の画像 2 JVC KW-V820BT Driver Side Panel Removal and Replacement, Driver Side Panel Removal and: 手順 12、 3の画像 3
    • Remove the six pan-head, 1/64 x 3/16" machine screws using a Phillips #0 screwdriver.
終わりに
作成者
2人の作成者と共同で作成されました。
Marshall Andersen
メンバー登録日: 10/02/18
665 ポイント
6のガイドは作成済み
チーム
Linn Benton Community College, Team S1-G6, Johnson Fall 2018 Linn Benton Community College, Team S1-G6, Johnson Fall 2018人のメンバー
LBCC-JOHNSON-F18S1G6
3 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 14
今までの合計 194
