メインコンテンツにスキップ
Fix Your Stuff
Right to Repair
Parts & Tools
はじめに
The LCD Screen on the GR-D93U is where the viewer can see the video that is being recorded and is where the playback is displayed. It is important to have the screen and can be frustrating if the screen is cracked or won't display content. The process of replacing the screens involves unscrewing a lot of screws so have a place that you will be able to keep the screws.
  1. Unscrew 3 mm Phillips #0 screws around the LCD Screen. You will have to turn the screen to get the screws on the bottom of the screen. Unscrew 3 mm Phillips #0 screws around the LCD Screen. You will have to turn the screen to get the screws on the bottom of the screen. Unscrew 3 mm Phillips #0 screws around the LCD Screen. You will have to turn the screen to get the screws on the bottom of the screen.
    • Unscrew 3 mm Phillips #0 screws around the LCD Screen. You will have to turn the screen to get the screws on the bottom of the screen.
  2. Pry apart the plastic casing around the screen using a flat spudger tool
    • Pry apart the plastic casing around the screen using a flat spudger tool
  3. Carefully remove the wires connected to the screen from the black box. Now you will be able to separate the screen from the camera. Carefully remove the wires connected to the screen from the black box. Now you will be able to separate the screen from the camera.
    • Carefully remove the wires connected to the screen from the black box. Now you will be able to separate the screen from the camera.
  4. Unscrew the 5 mm Phillips #0 screw that is connecting the screen to the plastic casing. Unscrew the 5 mm Phillips #0 screw that is connecting the screen to the plastic casing.
    • Unscrew the 5 mm Phillips #0 screw that is connecting the screen to the plastic casing.
  5. You can now take out the screen to be replaced. Carefully remove cables from the data board. You can now take out the screen to be replaced. Carefully remove cables from the data board. You can now take out the screen to be replaced. Carefully remove cables from the data board.
    • You can now take out the screen to be replaced. Carefully remove cables from the data board.
終わりに
Lindsay
メンバー登録日: 2015年03月16日
231 ポイント
2のガイドは作成済み
チーム
Colorado Springs, Team 1-5, May Spring 2015 Colorado Springs, Team 1-5, May Spring 2015人のメンバー
UCCS-MAY-S15S1G5
4 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 425
