メインコンテンツにスキップ
JVC GR-D72U Lateral Function Port Panel Replacement
必要な工具と部品
  1. JVC GR-D72U Lateral Function Port Panel Replacement, Battery: 手順 1、 2の画像 1 JVC GR-D72U Lateral Function Port Panel Replacement, Battery: 手順 1、 2の画像 2
    • Locate button on bottom of camera.
    • Slide button to the right.
  2. JVC GR-D72U Lateral Function Port Panel Replacement: 手順 2、 1の画像 1
    • Pull the battery towards the bottom of the camcorder while lifting battery .
  3. JVC GR-D72U Lateral Function Port Panel Replacement, Lateral Function Port Panel: 手順 3、 3の画像 1 JVC GR-D72U Lateral Function Port Panel Replacement, Lateral Function Port Panel: 手順 3、 3の画像 2 JVC GR-D72U Lateral Function Port Panel Replacement, Lateral Function Port Panel: 手順 3、 3の画像 3
    • Remove silver plate that says “Auto Light” on the top of the camera using a metal spudger.
    • Remove the 3.1 mm screw.
    • Remove the three 5.3 mm screws from the back of the camera.
  4. JVC GR-D72U Lateral Function Port Panel Replacement: 手順 4、 1の画像 1
    • From the bottom of the camera remove the following four screws:
    • 5.3 mm
    • 3.1 mm
    • 5.1 mm
    • 3.5 mm
  5. JVC GR-D72U Lateral Function Port Panel Replacement: 手順 5、 1の画像 1
    • Use the small plastic opening tool to remove the blue side cover piece.
  6. JVC GR-D72U Lateral Function Port Panel Replacement: 手順 6、 1の画像 1
    • Remove the 3.1 mm screw on top of the camera, closest to the LCD monitor.
    • Remove the 5.4 mm screw next to the snapshot button.
  7. JVC GR-D72U Lateral Function Port Panel Replacement: 手順 7、 1の画像 1
    • Remove the 3.1 mm screw next to the USB and DV inputs.
  8. JVC GR-D72U Lateral Function Port Panel Replacement: 手順 8、 1の画像 1
    • Gently pull apart both halves of the camera to reveal the inner components.
  9. JVC GR-D72U Lateral Function Port Panel Replacement: 手順 9、 3の画像 1 JVC GR-D72U Lateral Function Port Panel Replacement: 手順 9、 3の画像 2 JVC GR-D72U Lateral Function Port Panel Replacement: 手順 9、 3の画像 3
    この手順で使用する道具:
    • Flip the cable locks to the up-position and pull both cables connecting the lateral function port panel to the rest of the camera.
    • Insert the cables from the new port panel into their inputs and flip the locks to the down position.
    • It is easier to use tweezers when inserting the cable but not required.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Joshua Hatcherian
メンバー登録日: 09/28/17
194 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team S2-G2, Nance Fall 2017 USF Tampa, Team S2-G2, Nance Fall 2017人のメンバー
USFT-NANCE-F17S2G2
4 メンバー
5のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 9
今までの合計 528
