メインコンテンツにスキップ
JVC GR-D72U Cassette Holder Replacement
必要な工具と部品
  1. JVC GR-D72U Cassette Holder Replacement, Battery: 手順 1、 2の画像 1 JVC GR-D72U Cassette Holder Replacement, Battery: 手順 1、 2の画像 2
    • Locate button on bottom of camera.
    • Slide button to the right.
  2. JVC GR-D72U Cassette Holder Replacement: 手順 2、 1の画像 1
    • Pull the battery towards the bottom of the camcorder while lifting battery .
  3. JVC GR-D72U Cassette Holder Replacement, Lateral Function Port Panel: 手順 3、 3の画像 1 JVC GR-D72U Cassette Holder Replacement, Lateral Function Port Panel: 手順 3、 3の画像 2 JVC GR-D72U Cassette Holder Replacement, Lateral Function Port Panel: 手順 3、 3の画像 3
    • Remove silver plate that says “Auto Light” on the top of the camera using a metal spudger.
    • Remove the 3.1 mm screw.
    • Remove the three 5.3 mm screws from the back of the camera.
  4. JVC GR-D72U Cassette Holder Replacement: 手順 4、 1の画像 1
    • From the bottom of the camera remove the following four screws:
    • 5.3 mm
    • 3.1 mm
    • 5.1 mm
    • 3.5 mm
  5. JVC GR-D72U Cassette Holder Replacement: 手順 5、 1の画像 1
    • Use the small plastic opening tool to remove the blue side cover piece.
  6. JVC GR-D72U Cassette Holder Replacement: 手順 6、 1の画像 1
    • Remove the 3.1 mm screw on top of the camera, closest to the LCD monitor.
    • Remove the 5.4 mm screw next to the snapshot button.
  7. JVC GR-D72U Cassette Holder Replacement: 手順 7、 1の画像 1
    • Remove the 3.1 mm screw next to the USB and DV inputs.
  8. JVC GR-D72U Cassette Holder Replacement: 手順 8、 1の画像 1
    • Gently pull apart both halves of the camera to reveal the inner components.
  9. JVC GR-D72U Cassette Holder Replacement: 手順 9、 3の画像 1 JVC GR-D72U Cassette Holder Replacement: 手順 9、 3の画像 2 JVC GR-D72U Cassette Holder Replacement: 手順 9、 3の画像 3
    この手順で使用する道具:
    購入する
    • Flip the cable locks to the up-position and pull both cables connecting the lateral function port panel to the rest of the camera.
    • Insert the cables from the new port panel into their inputs and flip the locks to the down position.
    • It is easier to use tweezers when inserting the cable but not required.
  10. JVC GR-D72U Cassette Holder Replacement, Cassette Holder: 手順 10、 1の画像 1
    • From the inside of the camera remove these six screws.
    • 3.3 mm
    • 3.6 mm
    • 3.1 mm
    • 4.3 mm
    • 4.3 mm
    • 3.7 mm
  11. JVC GR-D72U Cassette Holder Replacement: 手順 11、 1の画像 1
    • Unplug the three cables from the circuit board.
  12. JVC GR-D72U Cassette Holder Replacement: 手順 12、 3の画像 1 JVC GR-D72U Cassette Holder Replacement: 手順 12、 3の画像 2 JVC GR-D72U Cassette Holder Replacement: 手順 12、 3の画像 3
    • From the top of the camera remove the two 3.1 mm screws securing the lens to the camera frame.
    • From the bottom of the camera remove the 3.2 mm screw next to the battery release switch.
    • Remove the 9.1 mm screw next to the menu and volume control label.
  13. JVC GR-D72U Cassette Holder Replacement: 手順 13、 2の画像 1 JVC GR-D72U Cassette Holder Replacement: 手順 13、 2の画像 2
    • Remove the lens cap housing.
    • Remove the two 3.1 mm screws from the inside of the camera.
  14. JVC GR-D72U Cassette Holder Replacement: 手順 14、 3の画像 1 JVC GR-D72U Cassette Holder Replacement: 手順 14、 3の画像 2 JVC GR-D72U Cassette Holder Replacement: 手順 14、 3の画像 3
    • Remove the plastic cover piece next to the silver light button.
    • Remove the 3.1 mm screw securing the lens to the circuit board.
    • Remove the two 3.3 mm screws from underneath the battery port.
  15. JVC GR-D72U Cassette Holder Replacement: 手順 15、 2の画像 1 JVC GR-D72U Cassette Holder Replacement: 手順 15、 2の画像 2
    • Take the cassette holder and circuit board by lifting it out of the camera frame.
    • Remove the two 3.6 mm screws.
    • Remove the two 1.8 mm screws then the plate.
    • If you are following this guide to replace the LED light or microphone you do not need to follow this step or the next step.
  16. JVC GR-D72U Cassette Holder Replacement: 手順 16、 3の画像 1 JVC GR-D72U Cassette Holder Replacement: 手順 16、 3の画像 2 JVC GR-D72U Cassette Holder Replacement: 手順 16、 3の画像 3
    • Remove the six cables (one is underneath the metal plate) connecting the cassette holder to the circuit board.
    • To unplug two of the cables you must first pull the lock tabs out (towards the cable) then remove the cable.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Jonah Powers
メンバー登録日: 09/28/17
437 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team S2-G2, Nance Fall 2017 USF Tampa, Team S2-G2, Nance Fall 2017人のメンバー
USFT-NANCE-F17S2G2
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 14
今までの合計 1,096
