メインコンテンツにスキップ
JVC Adixxion GC-XA1BU LCD Cover Replacement
必要な工具と部品
  1. JVC Adixxion GC-XA1BU LCD Cover Replacement, Battery: 手順 1、 1の画像 1
    • Find the side of the camera that looks like this.
  2. JVC Adixxion GC-XA1BU LCD Cover Replacement: 手順 2、 1の画像 1
    • Push down on the black switch.
  3. JVC Adixxion GC-XA1BU LCD Cover Replacement: 手順 3、 1の画像 1
    • While still pushing down on the black switch, slide back the battery cover (see photo for direction).
  4. JVC Adixxion GC-XA1BU LCD Cover Replacement: 手順 4、 2の画像 1 JVC Adixxion GC-XA1BU LCD Cover Replacement: 手順 4、 2の画像 2
    • Push the cover up to open the battery compartment, and then push the blue battery release switch.
  5. JVC Adixxion GC-XA1BU LCD Cover Replacement: 手順 5、 1の画像 1
    • You can now take the battery out of the camera.
  6. JVC Adixxion GC-XA1BU LCD Cover Replacement, Battery Cover: 手順 6、 1の画像 1
    • After removing the battery, take out the two Phillips screws (4mm headsize x 3mm length) screws. You can now remove the battery cover.
  7. JVC Adixxion GC-XA1BU LCD Cover Replacement, LCD Cover: 手順 7、 2の画像 1 JVC Adixxion GC-XA1BU LCD Cover Replacement, LCD Cover: 手順 7、 2の画像 2
    • Using a 1x1xH1.5 torx screwdriver, remove the 8 screws (5mm headsize / 4mm length) from the corners of both the front and back of the camera (4 screws on each side).
  8. JVC Adixxion GC-XA1BU LCD Cover Replacement: 手順 8、 1の画像 1
    • Carefully lift open the camera from the side of the device with the record and play buttons. Then remove the black cover tape by gently peeling it off. Make sure to save this tape as you may need it when you re-assemble the device.
  9. JVC Adixxion GC-XA1BU LCD Cover Replacement: 手順 9、 3の画像 1 JVC Adixxion GC-XA1BU LCD Cover Replacement: 手順 9、 3の画像 2 JVC Adixxion GC-XA1BU LCD Cover Replacement: 手順 9、 3の画像 3
    この手順で使用する道具:
    購入する
    • Using the tweezers, carefully push up the left and right sides of the cable ribbon clip. Use the tweezers to life up and remove the clip.
  10. JVC Adixxion GC-XA1BU LCD Cover Replacement: 手順 10、 2の画像 1 JVC Adixxion GC-XA1BU LCD Cover Replacement: 手順 10、 2の画像 2
    • Using the tweezers, carefully remove the ribbon cable by gently grasping it and pulling up.
  11. JVC Adixxion GC-XA1BU LCD Cover Replacement: 手順 11、 1の画像 1
    • Turn the camera 180 degrees, and gently remove the glue from the connector as shown in the photo. Make sure you save the glue as you may need it when re-assembling your device.
  12. JVC Adixxion GC-XA1BU LCD Cover Replacement: 手順 12、 3の画像 1 JVC Adixxion GC-XA1BU LCD Cover Replacement: 手順 12、 3の画像 2 JVC Adixxion GC-XA1BU LCD Cover Replacement: 手順 12、 3の画像 3
    • Now take out the connector by pulling the white clip out of the casing (as shown in the photos). This will will disconnect the screen from the main cable, allowing you to attach your new LCD cover.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Christina Michelle Johnson
メンバー登録日: 01/15/15
1,047 ポイント
8のガイドは作成済み
チーム
USF Tampa, Team 1-2, Tanski Winter 2015 USF Tampa, Team 1-2, Tanski Winter 2015人のメンバー
USFT-TANSKI-W15S1G2
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 345
