はじめに
This Guide will help you replace the battery inside a JBL Xtreme Bluetooth Speaker.
必要な工具と部品
For the first part of the case: gently pull back the edges of the case rotating along the hinge opposite the opening seam illustrated in the second photo. Plastic snaps hold the cover in place.
For the second part of the case: there are 2 screws to be removed at the seam. Once removed, the case will come off completely without forcing.
Unscrew the six 9.75mm Phillips head screws holding the bass radiator in place.
Locate the three 9.7mm Phillips head screws inside the zipper compartment and unscrew them.
Lift the zipper panel out of the speaker.
88 の人々がこのガイドを完成させました。
43 件のコメント
I couldn't find the battery specification anywhere in the Internet, so I removed it, easily following the well presented instructions above. The battery has two cells. The label on each cell says Greatpower, model no. GSP0931134, 7.4 volts, 5000 mah, 37Wh, made in China. Overall dimensions are 145mm x 32mm x 19mm (145mm includes a small electronic board where cables from the board connect to the plug.) After an Amazon and Google search, I'm no closer to a replacement. At least the reassembled Xtreme works without a battery with external power. JBL is of no help, either. I'll be looking model airplane stores, as they have every LiPo battery imaginable. In summary, the JBL Xtreme is a short lived unsupported product.
This is kinda late but were there any extra steps for running the speaker without a battery? Since the speaker is not working anymore at all, even with power connected, I would be happy to run it like this but am not sure whether it is really enough to just remove the battery.
So what this means is you have two lithium cells in parallel and those two are in series with another set of two, they are 3.7V nominal each. 2500mAh and 9.25Wh each.
I don't think this is a lipo battery (comes in all shapes and sizes, literally every dimension you could think of). The dimensions given are far too similar to 4 lithium ion 18650 (18x65mm) cells. Probably have +8 8 8- thats two cells with one lying on top of the other and nickel strip is going across the + of both cells and across the - of both cells. The next set of cells will be right behind it so it will look like this
+8 8 8- +8 8 8-
Imagine each o of the 8 is a cell, it was the easiest way to represent cells stacked on top of each other horizontally. The second set of cells are connected together with nickel strip exactly like the first set, putting them in parallel too. Pushing them together like in my "drawing" is what puts them in series (positive to negative). The single white wire on the 5 wire connector is the balance wire that
