メインコンテンツにスキップ
JBL Xtreme 3 Exterior Speaker Shell Cover Replacement
必要な工具と部品
  1. JBL Xtreme 3 Exterior Speaker Shell Cover Replacement, Exterior Speaker Shell Cover: 手順 1、 1の画像 1
    • Find the seam on the speaker and position it upwards.
    • Begin by turning the device to where the bottom side with groves are facing towards you, using the (5) spudger carefully pry open the side of the outer shell where the red indicators are to unlatch outer shell. After they are unlatched you should be able to open the shell by hand.
  2. JBL Xtreme 3 Exterior Speaker Shell Cover Replacement: 手順 2、 1の画像 1
    • To continue to remove the outer shell unscrew the two screws (size 1cm) shown in the picture with a size 0 (zero) Phillip's screwdriver.
  3. JBL Xtreme 3 Exterior Speaker Shell Cover Replacement: 手順 3、 2の画像 1 JBL Xtreme 3 Exterior Speaker Shell Cover Replacement: 手順 3、 2の画像 2
    • To continue to remove the shell use a (5) spudger to slowly pop the shell off.
    • There is one nudge in the center below the power and bluetooth button that should pop off.
    • Once you have unlatched this piece correctly the shell will remove itself from the speaker itself. As it is shown in the following figure.
終わりに
作成者
2人の作成者と共同で作成されました。
Devon Shaw
メンバー登録日: 09/16/22
214 ポイント
2のガイドは作成済み
チーム
Western Carolina University, Team 1-2, Virtue Fall 2022 Western Carolina University, Team 1-2, Virtue Fall 2022人のメンバー
WCU-VIRTUE-F22S1G2
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 46
今までの合計 681
