はじめに
Buttons can wear out over time due to wear and tear. This guide will show you how to remove the button panel on the bottom of the speaker.
Be CAREFUL when applying pressure to the button system, as to not damage or snap the system.
必要な工具と部品
Find the seam on the speaker and position it upwards.
Begin by turning the device to where the bottom side with groves are facing towards you, using the (5) spudger carefully pry open the side of the outer shell where the red indicators are to unlatch outer shell. After they are unlatched you should be able to open the shell by hand.
To continue to remove the shell use a (5) spudger to slowly pop the shell off.
There is one nudge in the center below the power and bluetooth button that should pop off.
Once you have unlatched this piece correctly the shell will remove itself from the speaker itself. As it is shown in the following figure.
Wedge the spudger between the outer button cover and the speaker hardware.
Gently push down on the spudger, lifting the outer button cover away from the device.
ある他の人がこのガイドを完成しました。
