メインコンテンツにスキップ
JBL Spyro/Spot Partial Disassembly
必要な工具と部品
  1. JBL Spyro/Spot Partial Disassembly, Locate the risers: 手順 1、 1の画像 1
    • Locate the 3 risers the hold the base plate in place
  2. JBL Spyro/Spot Partial Disassembly, Pry the plugs from the risers: 手順 2、 1の画像 1
    • Insert a strong spudger or flathead near the riser and gently pry until the plug starts to come out. Work your way around to loosening each one.
  3. JBL Spyro/Spot Partial Disassembly, Remove the base plate: 手順 3、 1の画像 1
    • With all three loosened remove the base!
    • Note the not equilateral placement of the risers when replacing the base.
終わりに
17 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Ryan McLeod
メンバー登録日: 05/22/10
606 ポイント
2のガイドは作成済み
11 件のコメント
Thanks, so nice tip. I'll see if I can find a similar speaker, big hug.
durval - 返信
My speaker is broken like on the image above and it sounds horrible. Do you know where to buy similar speaker in order to replice it?
pszopa - 返信
Does anybody know, if I can get a replacement speaker for the subwoofer of the JBL 2.1. system? Thanks!
Lars -
I was unable to find a replacement for the Atlas subwoofer it uses and ended up "recycling" the whole thing :( I've since replaced it with the the Klipsch ProMedia 2.1s and love them.
Ryan McLeod -
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 19
過去 30 日: 107
今までの合計 13,034
