メインコンテンツにスキップ
JBL Pulse 4 Outside Casing Replacement
必要な工具と部品
  1. JBL Pulse 4 Outside Casing Replacement, Casing Replacement: 手順 1、 1の画像 1
    • Power on JBL speaker before doing any repairs.
    • Hold the power button for 3+ seconds to power down the device.
  2. JBL Pulse 4 Outside Casing Replacement: 手順 2、 3の画像 1 JBL Pulse 4 Outside Casing Replacement: 手順 2、 3の画像 2 JBL Pulse 4 Outside Casing Replacement: 手順 2、 3の画像 3
    • Remove each rubber end cap using a plastic pry tool.
    • Go around each end of the speaker slowly popping up a small section of the rubber cap until there is a gap on all sides.
    • Remove the top by hand.
  3. JBL Pulse 4 Outside Casing Replacement: 手順 3、 3の画像 1 JBL Pulse 4 Outside Casing Replacement: 手順 3、 3の画像 2 JBL Pulse 4 Outside Casing Replacement: 手順 3、 3の画像 3
    • Remove the charging port cover using a plastic pry tool.
    • Remove the two 12.7 mm Phillips #1 screws.
    • Remove the charging port housing from the casing.
  4. JBL Pulse 4 Outside Casing Replacement: 手順 4、 3の画像 1 JBL Pulse 4 Outside Casing Replacement: 手順 4、 3の画像 2 JBL Pulse 4 Outside Casing Replacement: 手順 4、 3の画像 3
    • Disconnect the charging port connector by pulling the connector away from the port.
    • Disconnect the battery level indicator light by pulling the wire away from the lights.
  5. JBL Pulse 4 Outside Casing Replacement: 手順 5、 2の画像 1 JBL Pulse 4 Outside Casing Replacement: 手順 5、 2の画像 2
    • Remove the six 8 mm Phillips #1 screws from the end of the speaker with the grill that says "JBL."
    • Remove the plastic piece where the 6 screws came out of.
  6. JBL Pulse 4 Outside Casing Replacement: 手順 6、 1の画像 1
    • Remove the six 9.5 mm screws using a Phillips #1 screwdriver.
  7. JBL Pulse 4 Outside Casing Replacement: 手順 7、 3の画像 1 JBL Pulse 4 Outside Casing Replacement: 手順 7、 3の画像 2 JBL Pulse 4 Outside Casing Replacement: 手順 7、 3の画像 3
    • Flip the speaker to the other end.
    • Use a pry tool to pry between the casing of the speaker and the internals.
    • Go around the entirety of this end of the speaker slowly prying apart the two pieces.
  8. JBL Pulse 4 Outside Casing Replacement: 手順 8、 1の画像 1
    • The casing is now fully detached from the internal components.
    • You can now replace the outer casing of the speaker.
終わりに
作成者
3人の作成者と共同で作成されました。
Hank McDonough
メンバー登録日: 03/18/24
377 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 2-2, Konn Spring 2024 UMass Dartmouth, Team 2-2, Konn Spring 2024人のメンバー
UMASSD-KONN-S24S2G2
4 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 20
今までの合計 80
