メインコンテンツにスキップ
JBL Pulse 2 Battery Replacement
必要な工具と部品
  1. JBL Pulse 2 Battery Replacement, Battery: 手順 1、 2の画像 1 JBL Pulse 2 Battery Replacement, Battery: 手順 1、 2の画像 2
    • Remove the rubber rings from either end of the device.
    • If there is difficulty in lifting the rings from the device, use the metal spudger.
  2. JBL Pulse 2 Battery Replacement: 手順 2、 1の画像 1
    • Remove the four 4.8mm Phillips #1 screws from each end of the device with the Phillips head screwdriver.
    • Lift the end pieces off of the device.
  3. JBL Pulse 2 Battery Replacement: 手順 3、 1の画像 1
    • Remove the four 9.5mm Phillips #1 screws from each end of the device.
  4. JBL Pulse 2 Battery Replacement: 手順 4、 2の画像 1 JBL Pulse 2 Battery Replacement: 手順 4、 2の画像 2
    • Peel one end off and slowly draw it across the length of the device until you get to the other side.
  5. JBL Pulse 2 Battery Replacement: 手順 5、 3の画像 1 JBL Pulse 2 Battery Replacement: 手順 5、 3の画像 2 JBL Pulse 2 Battery Replacement: 手順 5、 3の画像 3
    • Remove the four 7.9mm Phillips #1 screws along the black centerpiece of the device between the camera and the auxiliary port.
    • Lift up the casing and circuit board but do not try and remove the ribbon wires.
  6. JBL Pulse 2 Battery Replacement: 手順 6、 1の画像 1
    • Remove the cover from the end that the ribbon wires are attached to. It should peel off easily.
  7. JBL Pulse 2 Battery Replacement: 手順 7、 2の画像 1 JBL Pulse 2 Battery Replacement: 手順 7、 2の画像 2
    • Unlatch the mechanism holding the ribbon wires in place, then disconnect them from the motherboard.
    • To access the wires, remove some of the black glue holding them in place with the spudger.
  8. JBL Pulse 2 Battery Replacement: 手順 8、 2の画像 1 JBL Pulse 2 Battery Replacement: 手順 8、 2の画像 2
    • Slowly pull the ribbon wires out from the outside.
    • If there is too much resistance, remove more of the black glue.
  9. JBL Pulse 2 Battery Replacement: 手順 9、 2の画像 1 JBL Pulse 2 Battery Replacement: 手順 9、 2の画像 2
    • Remove the four 7.9mm Phillips #1 screws around the edges of the center piece.
    • Slide the outer casing off away from the auxiliary and micro USB port.
  10. JBL Pulse 2 Battery Replacement: 手順 10、 1の画像 1
    • Remove the other end of the device to access the wiring underneath it.
  11. JBL Pulse 2 Battery Replacement: 手順 11、 1の画像 1
    • Use the angled tweezers to disconnect the battery from the motherboard. It will take some work to remove this piece.
  12. JBL Pulse 2 Battery Replacement: 手順 12、 1の画像 1
    • Remove the four 7.9mm Phillips #1 screws from the black centerpiece of the device.
  13. JBL Pulse 2 Battery Replacement: 手順 13、 2の画像 1 JBL Pulse 2 Battery Replacement: 手順 13、 2の画像 2
    • Use the spudger to reach under the sides of the black centerpiece to access the six latches, three of which are on each side.
  14. JBL Pulse 2 Battery Replacement: 手順 14、 2の画像 1 JBL Pulse 2 Battery Replacement: 手順 14、 2の画像 2
    • Lift the black centerpiece off with the metal spudger to reveal the battery underneath.
  15. JBL Pulse 2 Battery Replacement: 手順 15、 1の画像 1
    • Use a hot air gun to soften the hot glue in order to fully remove the battery.
終わりに
6 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Jarid Slopek
メンバー登録日: 08/31/18
448 ポイント
1ガイドが承認済み
チーム
Western Carolina University, Team S1-G1, Virtue Fall 2018 Western Carolina University, Team S1-G1, Virtue Fall 2018人のメンバー
WCU-VIRTUE-F18S1G1
4 メンバー
9のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 18
過去 30 日: 80
今までの合計 7,703
