はじめに
If you experience any difficulties with charging or playing music through an auxiliary cable, you may need to replace your JBL Pulse 2 speaker's auxiliary and micro USB ports.
必要な工具と部品
Remove the rubber rings from either end of the device.
If there is difficulty in lifting the rings from the device, use the metal spudger.
Remove the solder on the micro USB and Auxiliary port wires to disconnect them.
15 の人々がこのガイドを完成させました。
8 件のコメント
Is there a video out there to demonstrate this repair process?
Hallo, suche für die “JBL pulse 2” die Bauteile FB5 und D9 auf dem Mainboard.
Wer kennt diese Bauteile ?
Würde mich auf eine positive Antwort freuen.
Liebe Grüße J.R.
Bonjour pourriez-vous me dire ou acheter cette petite carte électronique merci.
