はじめに
To complete this guide, you will need to disassemble your device and use a soldering iron to replace the power jack.
必要な工具と部品
この手順で使用する道具:Desoldering Pump$3.99
Turn the device upside down.
Solder the back lead of the power jack until the solder melts.
Heat the lead until the solder melts.
Remove the solder with the desoldering pump.
もう少しです!
Replace the power jack with the new jack and resolder the leads. Follow the steps in reverse order to reassemble your device
終わりに
