メインコンテンツにスキップ
JBL On Stage II Power Jack Replacement
必要な工具と部品
  1. JBL On Stage II Power Jack Replacement, Cracking the Case: 手順 1、 1の画像 1
    • Turn the device upside down so that the three rubber pads are facing up.
  2. JBL On Stage II Power Jack Replacement: 手順 2、 1の画像 1
    • Use a heat gun (set to low) to apply heat to one of the rubber pads until you can easily remove the pad. This step takes around 5-7 minutes.
  3. JBL On Stage II Power Jack Replacement: 手順 3、 1の画像 1
    • Remove the heated rubber pad with a plastic opening tool.
    • Repeat steps 2 and 3 for the two remaining rubber pads.
  4. JBL On Stage II Power Jack Replacement: 手順 4、 2の画像 1 JBL On Stage II Power Jack Replacement: 手順 4、 2の画像 2
    • Remove the six 1cm T-10 torx screws on the bottom of the device (found under the rubber pads) using a T-10 Torx screwdriver.
  5. JBL On Stage II Power Jack Replacement: 手順 5、 3の画像 1 JBL On Stage II Power Jack Replacement: 手順 5、 3の画像 2 JBL On Stage II Power Jack Replacement: 手順 5、 3の画像 3
    • Open the device along its seam.
    • Be careful when separating the device because there are wires connecting the two seperate halves.
  6. JBL On Stage II Power Jack Replacement: 手順 6、 1の画像 1
    • Disconnect the ribbon cable connector from the top half of the device by pulling outward and parallel to the connecting pins.
  7. JBL On Stage II Power Jack Replacement: 手順 7、 2の画像 1 JBL On Stage II Power Jack Replacement: 手順 7、 2の画像 2
    • Locate and disconnect the two molex connectors found on either side of the ribbon cable connector on the bottom half of the device.
  8. JBL On Stage II Power Jack Replacement, Circuit Board: 手順 8、 2の画像 1 JBL On Stage II Power Jack Replacement, Circuit Board: 手順 8、 2の画像 2
    • Remove the three 1 cm T-10 Torx screws.
  9. JBL On Stage II Power Jack Replacement: 手順 9、 1の画像 1
    • Carefully press out the white base tube and push up on the circuit board.
    • Note that there is a small wire connecting the circuit board to the base.
  10. JBL On Stage II Power Jack Replacement: 手順 10、 2の画像 1 JBL On Stage II Power Jack Replacement: 手順 10、 2の画像 2
    • Pull the white wire out of the hot glue.
  11. JBL On Stage II Power Jack Replacement: 手順 11、 3の画像 1 JBL On Stage II Power Jack Replacement: 手順 11、 3の画像 2 JBL On Stage II Power Jack Replacement: 手順 11、 3の画像 3
    • Unbolt the heatsink with a 5.5-mm socket and a Phillips PH1 screwdriver.
    • Remove the heat sink; it should detach from the bottom of the device.
  12. JBL On Stage II Power Jack Replacement: 手順 12、 3の画像 1 JBL On Stage II Power Jack Replacement: 手順 12、 3の画像 2 JBL On Stage II Power Jack Replacement: 手順 12、 3の画像 3
    • Remove the T-10 torx screw on the bottom of the device that attaches the base tube to the circuit board.
    • Turn the device so that the base tube is on top.
    • Remove the base tube by pulling up.
    • May need to cut the rubber adhesive between the base tube to the circuit board.
  13. JBL On Stage II Power Jack Replacement, Power Jack: 手順 13、 3の画像 1 JBL On Stage II Power Jack Replacement, Power Jack: 手順 13、 3の画像 2 JBL On Stage II Power Jack Replacement, Power Jack: 手順 13、 3の画像 3
    • Turn the device upside down.
    • Solder the back lead of the power jack until the solder melts.
    • Heat the lead until the solder melts.
    • Remove the solder with the desoldering pump.
    • For help with soldering view the iFixit soldering guide
  14. JBL On Stage II Power Jack Replacement: 手順 14、 1の画像 1
    • Repeat step 13 for the other two leads
  15. JBL On Stage II Power Jack Replacement: 手順 15、 1の画像 1
    • Remove the power jack.
終わりに
Replace the power jack with the new jack and resolder the leads. Follow the steps in reverse order to reassemble your device
作成者
4人の作成者と共同で作成されました。
Jared Everingham
メンバー登録日: 01/23/14
362 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 9-28, Maness Winter 2014 Cal Poly, Team 9-28, Maness Winter 2014人のメンバー
CPSU-MANESS-W14S9G28
4 メンバー
7のガイドは作成済み
コメント 1 件
Do you know where to find a sound jack for my JBL On Stage? Thanks
David Díaz - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 1,092
