メインコンテンツにスキップ
JBL On Stage II 30-Pin Connector Replacement
必要な工具と部品
  1. JBL On Stage II 30-Pin Connector Replacement, Cracking the Case: 手順 1、 1の画像 1
    • Turn the device upside down so that the three rubber pads are facing up.
  2. JBL On Stage II 30-Pin Connector Replacement: 手順 2、 1の画像 1
    • Use a heat gun (set to low) to apply heat to one of the rubber pads until you can easily remove the pad. This step takes around 5-7 minutes.
  3. JBL On Stage II 30-Pin Connector Replacement: 手順 3、 1の画像 1
    • Remove the heated rubber pad with a plastic opening tool.
    • Repeat steps 2 and 3 for the two remaining rubber pads.
  4. JBL On Stage II 30-Pin Connector Replacement: 手順 4、 2の画像 1 JBL On Stage II 30-Pin Connector Replacement: 手順 4、 2の画像 2
    • Remove the six 1cm T-10 torx screws on the bottom of the device (found under the rubber pads) using a T-10 Torx screwdriver.
  5. JBL On Stage II 30-Pin Connector Replacement: 手順 5、 3の画像 1 JBL On Stage II 30-Pin Connector Replacement: 手順 5、 3の画像 2 JBL On Stage II 30-Pin Connector Replacement: 手順 5、 3の画像 3
    • Open the device along its seam.
    • Be careful when separating the device because there are wires connecting the two seperate halves.
  6. JBL On Stage II 30-Pin Connector Replacement: 手順 6、 1の画像 1
    • Disconnect the ribbon cable connector from the top half of the device by pulling outward and parallel to the connecting pins.
  7. JBL On Stage II 30-Pin Connector Replacement: 手順 7、 2の画像 1 JBL On Stage II 30-Pin Connector Replacement: 手順 7、 2の画像 2
    • Locate and disconnect the two molex connectors found on either side of the ribbon cable connector on the bottom half of the device.
    Where do I find these speakers
    HighChief - 返信
  8. JBL On Stage II 30-Pin Connector Replacement, 30-Pin Connector Replacement: 手順 8、 1の画像 1
    • Apply heat with a heatgun on a low setting to the area around the 30-pin connector until you can easily pry it out by the seam surrounding it (about 10 minutes).
  9. JBL On Stage II 30-Pin Connector Replacement: 手順 9、 1の画像 1
    • Use a metal spudger to pry out the plastic surrounding the 30-pin connector.
  10. JBL On Stage II 30-Pin Connector Replacement: 手順 10、 1の画像 1
    • Use a pair of tweezers to wiggle out the 30-pin connector.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Janessa D Cabrera
メンバー登録日: 01/23/14
514 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 9-28, Maness Winter 2014 Cal Poly, Team 9-28, Maness Winter 2014人のメンバー
CPSU-MANESS-W14S9G28
4 メンバー
7のガイドは作成済み
2 件のコメント
and how you get a new one of the 30 pin connector?
bini barazany - 返信
Yes, where can we buy a new one of the 30 pin connector?
Jimbo - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 9
今までの合計 4,426
