はじめに
If the grille of your JBL Go 3 becomes cracked, damaged, or loose due to a crack, use this guide to remove and replace the grille.
Before beginning, make sure to completely turn off your speaker.
必要な工具と部品
Using an iFixit Opening Pick or a Jimmy, pry along the seam between the rubber outer layer and the hard shell.
Work your way around the edges until the shell loosens and can be fully removed.
終わりに
To reassemble your device, follow these steps in reverse order.
