メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
JBL Flip 3 Power Circuit Board Replacement
必要な工具と部品
  1. JBL Flip 3 Power Circuit Board Replacement, Power Circuit Board: 手順 1、 1の画像 1
    • Remove plastic outer housing using hands or a standard spudger.
    • Important! Note the three alignment pins on the inner part of the housing. When reassembling, take special care to line these up and insert the pins into the receivers on the chassis prior to snapping the edges into place.
  2. JBL Flip 3 Power Circuit Board Replacement: 手順 2、 1の画像 1
    • Carefully remove outer housing to expose the inner components of the speaker.
  3. JBL Flip 3 Power Circuit Board Replacement: 手順 3、 1の画像 1
    • Remove the silicone button cover to expose the power chip.
  4. JBL Flip 3 Power Circuit Board Replacement: 手順 4、 1の画像 1
    • Heat the adhesive at the far end of the chip where the ribbon goes down into the device. Using the spudger, gently pry the chip off the board. Be careful not to melt the plastic edging during heating.
    • Heat gun safety: http://www.powertoolinstitute.com/pti_pd...
終わりに
14 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
James Bianco
メンバー登録日: 02/20/17
151 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team S1-G2, Leahy Spring 2017 USF Tampa, Team S1-G2, Leahy Spring 2017人のメンバー
USFT-LEAHY-S17S1G2
5 メンバー
19のガイドは作成済み
5件のガイドコメント
If your gentle, you don’t need a heat gun. I carefully removed it with a screwdriver. Just don’t stress the board else your in a new set of problems.
Tyler Freeman - 返信 共有
How do you remove the board? It says to remove the chip from the board but there are no images that show that.
Brian Barlow - 返信 共有
The title says replacement, and you show only the removal.
Stanimir Nikolov - 返信 共有
what could be a problem with my jbl flip 3.it wouldn't turn on when its not plugged in to the charger.
Miss D - 返信 共有
Change the battery
odii Emmanuel - 共有
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 21
過去 30 日: 93
今までの合計 32,653
