はじめに
Headphones not powering on? It may be caused by the charging port malfunctioning, which may cause the headphones to not charge, making them unusable. Here's a guide to replace it! All you need is a Phillips #000 screwdriver, a soldering iron, and an iFixit opening tool.
必要な工具と部品
Remove the .5mm screw on the headphone jack circuit board that is covering the charging port.
もう少しです!
終わりに
