メインコンテンツにスキップ
JBL Clip 2 Speaker Replacement
必要な工具と部品
  1. JBL Clip 2 Speaker Replacement, Speaker: 手順 1、 1の画像 1
    • Begin by removing the front cap of the JBL Clip 2 by using the blue plastic opening tool to get in between the creases.
    • If your JBL Clip 2 has never been opened this procedure will require moderate amount of force.
  2. JBL Clip 2 Speaker Replacement: 手順 2、 1の画像 1
    • There will be six 3 mm T8 screws under the cap, remove these six screws.
  3. JBL Clip 2 Speaker Replacement: 手順 3、 1の画像 1
    • The front cover will lift open easily and the components will be visible.
  4. JBL Clip 2 Speaker Replacement: 手順 4、 1の画像 1
    • To completely remove the top portion, disconnect the speaker from the motherboard using the blue plastic opening tool.
    • While disconnecting be sure to not use too much force as these two parts are meant to become disconnected.
終わりに
4 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Michael Hong
メンバー登録日: 02/01/17
1,041 ポイント
5のガイドは作成済み
チーム
UW Tacoma, Team 2-2, Rose Winter 2017 UW Tacoma, Team 2-2, Rose Winter 2017人のメンバー
UWT-ROSE-W17S2G2
4 メンバー
7のガイドは作成済み
6件のガイドコメント
If no parts are required what are you replacing the speaker with?
Tom - 返信
Tom is right you know!
edward felix - 返信
The grill was glued into the T8 recesses. It needs glue to resemble. But how not to ruin the T8 heads for future work?
Gus Cannon - 返信
please we need to know where we can buy replacement speakers thanks email: chris.vargasrobles@gmail.com
chris robles - 返信
Hi, where I can buy the speaker please? Thank you.
Govan - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 55
今までの合計 6,866
