この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Removing the motherboard will allow access to most of the internal components.
必要な工具と部品
Make sure the device is powered off before you begin to disassemble the speaker.
Remove the trim from the speaker using a jimmy or metal spudger.
7 の人々がこのガイドを完成させました。
14 件のコメント
Hello I have 3 jbl speakers I bought that work only if plugged to the wall and aux cable... other than that it doesn't work at all .. Bluetooth or even the buttons don't function
had same issue. fixed it by reconnecting the cable that conncts LEDs/ buttons
i have the same problem
hello can i ask if how many pins in the flex for power button i accidentally damage when i fixed it
