メインコンテンツにスキップ
JBL Charge 5 Passive Bass Radiators Replacement
必要な工具と部品
  1. JBL Charge 5 Passive Bass Radiators Replacement, Fabric Case: 手順 1、 3の画像 1 JBL Charge 5 Passive Bass Radiators Replacement, Fabric Case: 手順 1、 3の画像 2 JBL Charge 5 Passive Bass Radiators Replacement, Fabric Case: 手順 1、 3の画像 3
    • Ensure that the device is fully powered off and no cables are attached before proceeding with the repair.
    • This fabric cover is secured with plastic clips only. Depending on the model, the cover may be secured by both plastic clips and screws.
    • Insert the flat end of the Jimmy into the seam located between the fabric cover on the right side of the seam.
    • Pry upward on the fabric cover to release plastic clips on the right side of the seam.
  2. JBL Charge 5 Passive Bass Radiators Replacement: 手順 2、 3の画像 1 JBL Charge 5 Passive Bass Radiators Replacement: 手順 2、 3の画像 2 JBL Charge 5 Passive Bass Radiators Replacement: 手順 2、 3の画像 3
    • Insert the flat end of the Jimmy into the seam between the fabric cover at the center of the seam and the left side of the seam.
    • Use the Jimmy to pry open the edge with the rubber texture, releasing the remaining plastic clips.
  3. JBL Charge 5 Passive Bass Radiators Replacement: 手順 3、 3の画像 1 JBL Charge 5 Passive Bass Radiators Replacement: 手順 3、 3の画像 2 JBL Charge 5 Passive Bass Radiators Replacement: 手順 3、 3の画像 3
    • Use your hands to gently open the two halves of the casing and slide the fabric cover off of the interior housing.
  4. JBL Charge 5 Passive Bass Radiators Replacement, Passive Bass Radiators: 手順 4、 3の画像 1 JBL Charge 5 Passive Bass Radiators Replacement, Passive Bass Radiators: 手順 4、 3の画像 2 JBL Charge 5 Passive Bass Radiators Replacement, Passive Bass Radiators: 手順 4、 3の画像 3
    • Using a spudger, pry the radiator off of the frame of the device.
    • Repeat on the other side if necessary.
終わりに
作成者
3人の作成者と共同で作成されました。
Kat Whaley
メンバー登録日: 09/13/23
753 ポイント
6のガイドは作成済み
チーム
Western Carolina University, Team 1-2, Virtue Fall 2023 Western Carolina University, Team 1-2, Virtue Fall 2023人のメンバー
WCU-VIRTUE-F23S1G2
5 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 48
今までの合計 303
