メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
JBL Charge 3 Speaker Replacement
必要な工具と部品
  1. JBL Charge 3 Speaker Replacement, Front Cover: 手順 1、 3の画像 1 JBL Charge 3 Speaker Replacement, Front Cover: 手順 1、 3の画像 2 JBL Charge 3 Speaker Replacement, Front Cover: 手順 1、 3の画像 3
    • Turn your speaker upside down and insert the plastic opening tool vertically into the slit in the front cover.
    • Slowly pull the plastic opening tool outward to remove the four clips holding the covering in place.
    • Repeat this process for all four edges of the front cover.
  2. JBL Charge 3 Speaker Replacement: 手順 2、 1の画像 1
    • Pull apart your cover gently from both sides and remove it from the speaker housing.
    • There are screws around the foot of the device that may need loosening to be able to unclip the other side of the cover.
    • The inside of the front cover has holes that must match with their corresponding pins on the speaker housing for proper reassembly.
    • Removing the Front Cover does not affect the waterproof seals of the device. However, removing any further disassembly of your speaker will require removing waterproof seals and gaskets. Your device may no longer be waterproof after these have been altered.
  3. JBL Charge 3 Speaker Replacement, Speaker: 手順 3、 2の画像 1 JBL Charge 3 Speaker Replacement, Speaker: 手順 3、 2の画像 2
    • Remove the eight 10mm Phillips #1 screws from around the two front speakers.
  4. JBL Charge 3 Speaker Replacement: 手順 4、 1の画像 1
    • Pull gently on one of the speakers so it is outside of the housing. Be careful as it is still attached with the wires to the motherboard.
  5. JBL Charge 3 Speaker Replacement: 手順 5、 3の画像 1 JBL Charge 3 Speaker Replacement: 手順 5、 3の画像 2 JBL Charge 3 Speaker Replacement: 手順 5、 3の画像 3
    • Press the small metal tab on the speaker connector with a Phillips #000 screwdriver and gently pull the connector apart.
  6. JBL Charge 3 Speaker Replacement: 手順 6、 1の画像 1
    • Repeat the previous step for the second connector.
  7. JBL Charge 3 Speaker Replacement: 手順 7、 2の画像 1 JBL Charge 3 Speaker Replacement: 手順 7、 2の画像 2
    この手順で使用する道具:
    • Grab the bundled cable connector that joins the speakers to the motherboard with tweezers. Gently pull the connector free.
  8. JBL Charge 3 Speaker Replacement: 手順 8、 1の画像 1
    • Now that the second speaker is disconnected from the motherboard, pull the speaker and wires out of the housing.
終わりに
48 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Aidan Hays
メンバー登録日: 10/08/18
4,343 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S13-G1, White Fall 2018 Cal Poly, Team S13-G1, White Fall 2018人のメンバー
CPSU-WHITE-F18S13G1
3 メンバー
26のガイドは作成済み
33件のガイドコメント
Where I can buy the same jbl speaker ?
Ekinox - 返信 共有
I need to replace my JBL charge 3 speaker
Lara Esther - 共有
Where can buy the small speakers? Helpp
Luis Cilia - 返信 共有
I have to pull out the motherboard to get those speakers out.
Tr0ll05aur0s 3z - 返信 共有
where can i buy the replacement speakers?
Yhamani Pangarungan - 返信 共有
コメントを追加
統計データ:
過去 24時間: 20
過去 7 日: 154
過去 30 日: 642
今までの合計 106,890
