はじめに
The JBL Charge 3 has two front speaker that can be replaced individually or together. If your speakers are blown out replace them with this guide.
  1. Turn your speaker upside down and insert the plastic opening tool vertically into the slit in the front cover. Slowly pull the plastic opening tool outward to remove the four clips holding the covering in place. Repeat this process for all four edges of the front cover.
    • Turn your speaker upside down and insert the plastic opening tool vertically into the slit in the front cover.
    • Slowly pull the plastic opening tool outward to remove the four clips holding the covering in place.
    • Repeat this process for all four edges of the front cover.
  2. Pull apart your cover gently from both sides and remove it from the speaker housing.
    • Pull apart your cover gently from both sides and remove it from the speaker housing.
    • The inside of the front cover has holes that must match with their corresponding pins on the speaker housing for proper reassembly.
    • Removing the Front Cover does not affect the waterproof seals of the device. However, removing any further disassembly of your speaker will require removing waterproof seals and gaskets. Your device may no longer be waterproof after these have been altered.
  3. Remove the eight 10mm Phillips #1 screws from around the two front speakers. Remove the eight 10mm Phillips #1 screws from around the two front speakers.
    • Remove the eight 10mm Phillips #1 screws from around the two front speakers.
  4. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  5. Pull gently on one of the speakers so it is outside of the housing. Be careful as it is still attached with the wires to the motherboard.
    • Pull gently on one of the speakers so it is outside of the housing. Be careful as it is still attached with the wires to the motherboard.
  6. Press the small metal tab on the speaker connector with a Phillips #000 screwdriver and gently pull the connector apart. Press the small metal tab on the speaker connector with a Phillips #000 screwdriver and gently pull the connector apart. Press the small metal tab on the speaker connector with a Phillips #000 screwdriver and gently pull the connector apart.
    • Press the small metal tab on the speaker connector with a Phillips #000 screwdriver and gently pull the connector apart.
  7. Repeat the previous step for the second connector.
    • Repeat the previous step for the second connector.
  8. Grab the bundled cable connector that joins the speakers to the motherboard with tweezers. Gently pull the connector free. Grab the bundled cable connector that joins the speakers to the motherboard with tweezers. Gently pull the connector free.
    • Grab the bundled cable connector that joins the speakers to the motherboard with tweezers. Gently pull the connector free.
  9. Now that the second speaker is disconnected from the motherboard, pull the speaker and wires out of the housing.
    • Now that the second speaker is disconnected from the motherboard, pull the speaker and wires out of the housing.
まとめ
ある他の人がこのガイドを完成しました。
Aidan Hays
メンバー登録日: 2018年10月08日
317 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S13-G1, White Fall 2018 Cal Poly, Team S13-G1, White Fall 2018人のメンバー
CPSU-WHITE-F18S13G1
4 メンバー
14のガイドは作成済み
Where I can buy the same jbl speaker ?
Ekinox - 返信
Where can buy the small speakers? Helpp
Luis Cilia - 返信
I have to pull out the motherboard to get those speakers out.
Tr0ll05aur0s 3z - 返信
統計データを表示:
過去 24時間: 30
過去 7 日: 269
過去 30 日: 1,085
今までの合計 2,316
