メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
JBL Charge 3 Port Bay Replacement
必要な工具と部品
    1. JBL Charge 3 Port Bay Replacement, Front Cover: 手順 1、 3の画像 1 JBL Charge 3 Port Bay Replacement, Front Cover: 手順 1、 3の画像 2 JBL Charge 3 Port Bay Replacement, Front Cover: 手順 1、 3の画像 3
      • Turn your speaker upside down and insert the plastic opening tool vertically into the slit in the front cover.
      • Slowly pull the plastic opening tool outward to remove the four clips holding the covering in place.
      • Repeat this process for all four edges of the front cover.
      FixBotに聞いてみる
      コメントを追加
    2. JBL Charge 3 Port Bay Replacement: 手順 2、 1の画像 1
      • Pull apart your cover gently from both sides and remove it from the speaker housing.
      • There are screws around the foot of the device that may need loosening to be able to unclip the other side of the cover.
      • The inside of the front cover has holes that must match with their corresponding pins on the speaker housing for proper reassembly.
      • Removing the Front Cover does not affect the waterproof seals of the device. However, removing any further disassembly of your speaker will require removing waterproof seals and gaskets. Your device may no longer be waterproof after these have been altered.
      FixBotに聞いてみる
      コメントを追加
    1. JBL Charge 3 Port Bay Replacement, Port Bay: 手順 3、 3の画像 1 JBL Charge 3 Port Bay Replacement, Port Bay: 手順 3、 3の画像 2 JBL Charge 3 Port Bay Replacement, Port Bay: 手順 3、 3の画像 3
      • Take out the four 8mm Phillips #1 screws out of the port bay cover.
      • Wedge your plastic opening tool around the port bay to remove it.
      FixBotに聞いてみる
      コメントを追加
    2. JBL Charge 3 Port Bay Replacement: 手順 4、 3の画像 1 JBL Charge 3 Port Bay Replacement: 手順 4、 3の画像 2 JBL Charge 3 Port Bay Replacement: 手順 4、 3の画像 3
      • Disconnect the two bundled cable connector from the port bay.
      FixBotに聞いてみる
      コメントを追加
    3. JBL Charge 3 Port Bay Replacement: 手順 5、 3の画像 1 JBL Charge 3 Port Bay Replacement: 手順 5、 3の画像 2 JBL Charge 3 Port Bay Replacement: 手順 5、 3の画像 3
      • Remove the three 8mm Phillips #1 screws from the port bay circuit board.
      • Pull the port bay cover off of the circuit board.
      FixBotに聞いてみる
      コメントを追加
    4. JBL Charge 3 Port Bay Replacement: 手順 6、 2の画像 1 JBL Charge 3 Port Bay Replacement: 手順 6、 2の画像 2
      • Desolder the USB, MicroUSB, or AUX port off of the circuit board.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
42 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Jack Ng
メンバー登録日: 10/08/18
2,446 ポイント
4のガイドは作成済み
17件のガイドコメント
Is there a place to buy an entire replacement port bay?
indecisive_decision - 返信 共有
Found the whole assembly on line for 30 bucks. Or a usb port for five from jbl
bonnie.1964 - 返信 共有
Can u share a link? Need a new port bay!
Max de Groot - 返信 共有
Hello! My jbl charge 3 has a problem in bluetooth, I can't detect the bluetooth in any gadget. Is there anybody have an idea how to fix this?
ebataluna - 返信 共有
anyone have the charging ways of this board i have 2 pads missing and would like to run the lines
Juju B - 返信 共有
コメントを追加
統計データ:
過去 24時間: 11
過去 7 日: 89
過去 30 日: 470
今までの合計 71,467
