はじめに
Going on to further repairs or just replacing a broken front cover? This guide will teach you the first step of opening up your JBL Charge 3.
必要な工具と部品
Turn your speaker upside down and insert the plastic opening tool vertically into the slit in the front cover.
Slowly pull the plastic opening tool outward to remove the four clips holding the covering in place.
Repeat this process for all four edges of the front cover.
6 の人々がこのガイドを完成させました。
2 件のコメント
where can i buy a new front cover for mine? mine has got cracked
It seems there may be different versions of Charge 3 covers in existence, as when I opened mine (carefully with a slim screwdriver) I was presented with a single cross head screw on each end which was holding one of the ends of the cover in place. I could remove the top end at both ends, but had to unscrew these screws to get the other end off. It was easy, just deviates from this guide quite a bit!
