メインコンテンツにスキップ
JBL Charge 3 Front Cover Replacement
必要な工具と部品
  1. JBL Charge 3 Front Cover Replacement, Front Cover: 手順 1、 3の画像 1 JBL Charge 3 Front Cover Replacement, Front Cover: 手順 1、 3の画像 2 JBL Charge 3 Front Cover Replacement, Front Cover: 手順 1、 3の画像 3
    • Turn your speaker upside down and insert the plastic opening tool vertically into the slit in the front cover.
    • Slowly pull the plastic opening tool outward to remove the four clips holding the covering in place.
    • Repeat this process for all four edges of the front cover.
  2. JBL Charge 3 Front Cover Replacement: 手順 2、 1の画像 1
    • Pull apart your cover gently from both sides and remove it from the speaker housing.
    • The inside of the front cover has holes that must match with their corresponding pins on the speaker housing for proper reassembly.
    • Removing the Front Cover does not affect the waterproof seals of the device. However, removing any further disassembly of your speaker will require removing waterproof seals and gaskets. Your device may no longer be waterproof after these have been altered.
終わりに
6 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Aidan Hays
メンバー登録日: 10/08/18
3,815 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S13-G1, White Fall 2018 Cal Poly, Team S13-G1, White Fall 2018人のメンバー
CPSU-WHITE-F18S13G1
3 メンバー
26のガイドは作成済み
2 件のコメント
where can i buy a new front cover for mine? mine has got cracked
Cammy Innes - 返信
It seems there may be different versions of Charge 3 covers in existence, as when I opened mine (carefully with a slim screwdriver) I was presented with a single cross head screw on each end which was holding one of the ends of the cover in place. I could remove the top end at both ends, but had to unscrew these screws to get the other end off. It was easy, just deviates from this guide quite a bit!
Thomas Hall - 返信
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 20
過去 30 日: 88
今までの合計 9,000
