メインコンテンツにスキップ
はじめに
JBL Charge 3は2つのフロント向きスピーカーが搭載されており、個別で交換が可能です。スピーカーが破損している場合は、このガイドを参照して交換してください。
  1. スピーカーを裏返して、プラスチックのオープンツールを垂直にフロントカバーに差し込みます。 ゆっくりツールを外側に動かしてカバーを支えている4つの爪を外します。 このプロセスをフロントカバーの4つの端全てで繰り返します。
    • スピーカーを裏返して、プラスチックのオープンツールを垂直にフロントカバーに差し込みます。
    • ゆっくりツールを外側に動かしてカバーを支えている4つの爪を外します。
    • このプロセスをフロントカバーの4つの端全てで繰り返します。
    Sometimes disassemblers forget that the first time they disassembled the item it didn’t want to give up easily: I didn’t like the forces I was having to apply at all, so I switched to two plastic prying tools per “corner” and one in-between them (total 5, you could use plectrums…) before I was happy the the forces were low enough not to break anything.
    Frank Puranik - 返信
    the front grill is supposed to be first not the back the back has longer while the front has shorter clip
    Water Bass Tester (Water BT) - 返信
    There are two Phillips head screws to remove before prying the cover off
    jason - 返信
    Where in south Africa can I buy jbl charge3 port bay replacement
    Donovan Fransman - 返信
    There appears to be different versions of the Charge 3. If you find it difficult to pry open a second side the two small screws mentioned by Jason will need to be removed but it also indicates that there will be some additional changes to this tear down that I will try to convey in the comments as well.
    john Ramirez - 返信
    Sadly I damaged the latches on my charge 3. There was more to it than just prying the front cover up. First, there is a small latch on both sides that you need to push down before pulling the front cover towards you that release the clips holding the front cover in place. Pull only slightly forward because… Second, in the front cover there are 6 circular notches connected to the front cover in tue four corners including the middle corners, you need to squeeze the front cover a little bit gently removing the notches so they dont break (like mine did).
    ralphkeneth_gomz - 返信
    Definitely had to watch about 10 videos and still couldn’t get it to pop out easily.. Took a look at the first picture in the next step and really took note of where the little hole that lets you through to push down the tab is. Once I took a look at that and combined the techniques I’d seen in some of the videos it finally popped off easily. https://www.youtube.com/watch?v=u7i0_nD9... I only watched the first minute of this video but it helped a good bit if anyone else is having trouble.
    Rowan Darko - 返信
  2. カバーをゆっくり両方のサイドから引っ張り、スピーカーのハウジングから外します。
    • カバーをゆっくり両方のサイドから引っ張り、スピーカーのハウジングから外します。
    • フロントカバーの内側にはいくつかの穴があり、もとに戻すときはハウジングのピンと合わせてください。
    • フロントカバーを外しても、デバイスの防水性能には影響ありません。しかしこれより解体すると、防水シールやガスケットを取り外すことになります。つまり、このデバイスは防水機能を失ってしまいます。
    Include dissembling the plastic cover? cover?
    KanGoon - 返信
    @KanGoon Yes, on mine it took the removal of 6 (reasonably obvious) screws to remove that. I’ll try to insert a photo when I reassemble…
    Frank Puranik - 返信
    Very good guide! Pics and descriptions make this easy!
    John G Petko - 返信
    There is a step missing here. How do you remove the rubber cover that covers the port?
    Phillip Luebke - 返信
    Gibt es eine Möglichkeit diese wieder wasserdicht zu bekommen?
    Furkan Karakelle - 返信
  3. 2つのフロント向きスピーカーから#1 プラスネジを8本外します。 2つのフロント向きスピーカーから#1 プラスネジを8本外します。
    • 2つのフロント向きスピーカーから#1 プラスネジを8本外します。
    Die Frage : Ist ob man irgendwo Ersatz Lautsprecher bekommt ???
    nicowihnaleck - 返信
    Probier's mal hier, vergleiche aber ganz genau (Seriennummer GG…):
    https://ecommerce.mysav.eu/en/jbl/147-sp...
    VauWeh - 返信
  4. スピーカーのうち一つを慎重に引き抜きます。マザーボードとワイヤが繋がったままの状態です。ご注意ください。
    • スピーカーのうち一つを慎重に引き抜きます。マザーボードとワイヤが繋がったままの状態です。ご注意ください。
  5. #000 プラスドライバーを使って、スピーカーコネクタ上の小さなメタルタブを押し込んで、慎重にコネクタを引き抜いて外します。 #000 プラスドライバーを使って、スピーカーコネクタ上の小さなメタルタブを押し込んで、慎重にコネクタを引き抜いて外します。 #000 プラスドライバーを使って、スピーカーコネクタ上の小さなメタルタブを押し込んで、慎重にコネクタを引き抜いて外します。
    • #000 プラスドライバーを使って、スピーカーコネクタ上の小さなメタルタブを押し込んで、慎重にコネクタを引き抜いて外します。
    Where can l buy those speaker for replacing
    Terrence Terrence - 返信
    Somebody know where I can buy These speakers ?
    motje - 返信
  6. 2番目のコネクタにも同じ作業を繰り返します。
    • 2番目のコネクタにも同じ作業を繰り返します。
  7. スピーカーとマザーボードを繋いでいる結束したケーブルのコネクタをピンセットで摘んで、コネクタを引き抜きます。 スピーカーとマザーボードを繋いでいる結束したケーブルのコネクタをピンセットで摘んで、コネクタを引き抜きます。
    • スピーカーとマザーボードを繋いでいる結束したケーブルのコネクタをピンセットで摘んで、コネクタを引き抜きます。
  8. これで2番目のスピーカーをマザーボードから接続が外れています。
    • これで2番目のスピーカーをマザーボードから接続が外れています。
    where can i buy these speaker,i need to replace the left side speaker because it was already damaged
    geoffrey mustar - 返信
終わりに
このデバイスを再組み立てするには、インストラクションを逆の順番に従って作業を進めてください。
30 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
翻訳を始める ›
Aidan Hays
メンバー登録日: 2018年10月08日
2,272 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S13-G1, White Fall 2018 Cal Poly, Team S13-G1, White Fall 2018人のメンバー
CPSU-WHITE-F18S13G1
3 メンバー
19のガイドは作成済み
22 件のコメント
Where I can buy the same jbl speaker ?
Ekinox - 返信
Where can buy the small speakers? Helpp
Luis Cilia - 返信
I have to pull out the motherboard to get those speakers out.
Tr0ll05aur0s 3z - 返信
where can i buy the replacement speakers?
Yhamani Pangarungan - 返信
Mine did not have the little clips in step 5. It was just soldered on. I ended up removing it from the other end. At the little white clip that goes in the motherboard (shown in step &) I was able to remove the pin. by pressing down on the top where you can see the silver.
Mike - 返信
It doesn’t seem possible to buy replacement speaker units.
dave - 返信
I see them on ebay, there are two designs. Btw, my speakers don't have clips, they are soldered on.
Erwin Johnson - 返信
i just completed this repair using generic replacement speakers from ali express item number 32829635211
mine were soldered on. i had to trim 4 orientation posts that prevent the factory speakers being installed rotated incorrectly, as these wouldn’t work with the new speakers. they sound OK, but have noticeably less bass than the OEM JBL drivers and can sound a little more tinny. there are also people doing it on ebay for 30$, but i am not in the USA so that was not convenient.
ivan@absolutehid
ivan - 返信
Where can I buy these same speakers
Silvester Whitehurst - 返信
San mkabili ng orig.na speaker ng jbl3?
rodolfom.afan - 返信
where I can buy these speakers. also need it for India region . but as I checked not able to buy it .
Prince Gupta - 返信
Contact JBL customer service if y3have or gen get the teveipt call them and then email pic8or the receipt ant the JBL Serial number by the speakers when the blabk jbl grill is off if less than 12 months old youll get a free speaker replacement if out warranty or you have no receipt the replacement speaker for Charge3 is only $32.19 USD. Good luck.
David Lorince - 返信
Contact JBL customer service if you have a charge 3. get the customer service number, call them and or then just email description fate SN# and pic of the receipt and the JBL Serial number between the speakers when the black JBL grill is off, but only if its less than 12 months old then you’ll get a free speaker replacement if out warranty or you have no receipt the replacement speaker for it is cheap only the JBL Charge3 is only $32.19 USD. Good luck.
David Lorince - 返信
If you can find a cheap replacement battery for $20 grab it cause its totally worth it if out in the wilderness it also acts as a cellphone charger.
David Lorince - 返信
Fyi upset neighbors since my left charge 3 is blown i decided it daisy chain 3 50 wayt pyle horn tweeters omg lets just day its about 500p% louder. Lol. Happy 4th of
David Lorince - 返信
Do you have a specific link for this OEM JBL charge 3 speaker replacement or are you just directing us to the JBL company where they currently want $35 + shipping on a single speaker unless the Charge 4 and Flip 4 lower these crazy prices. Has any one found a similar Charge 3 speaker replacement that’s louder and cheaper ???
David Lorince - 返信
For anyone that is wondering where to buy the speaker replacement, you can find it on all express just search up JBL charge 3 speaker replacement.
Armin Aghayan - 返信
Absolutely ridiculous how much replacement speakers are! I found some that “work” but they sound like crap…… Considering I have 4 Charge3’s and 1 Charge4, Harmon already has PLENTY of my $$!
Sheldon Abbey - 返信
JBL Charge 3 -
vorrei acquistare la coppia di casse uguale modello e dimensioni potreste fornirmi l’articolo a il link x ordinarli grazie
I would like to purchase the pair of speakers of the same model and size, could you provide me with the article at the link to order them, thank you
roberto - 返信
Ciao @flipok ! Maybe you can find some options in this Answer on our Forum: Where to buy replacement speakers for JBL Charge 3? Good luck!
Claire Miesch -
コメントを追加
統計データを表示:
過去 24時間: 34
過去 7 日: 276
過去 30 日: 1,069
今までの合計 50,736
