メインコンテンツにスキップ
JBL Charge 2 Motherboard Replacement
必要な工具と部品
  1. JBL Charge 2 Motherboard Replacement, Battery: 手順 1、 1の画像 1
    • Remove the screen cover from the speaker using a metal spudger.
  2. JBL Charge 2 Motherboard Replacement: 手順 2、 2の画像 1 JBL Charge 2 Motherboard Replacement: 手順 2、 2の画像 2
    • Using a Phillips #1 screwdriver (PH1), remove the (4) four 8mm screws.
    • Remove the end cap of the device. Repeat the same process to remove the other end cap.
  3. JBL Charge 2 Motherboard Replacement: 手順 3、 2の画像 1 JBL Charge 2 Motherboard Replacement: 手順 3、 2の画像 2
    • To remove the end diaphragms, use a Phillips #1 screwdriver (PH1) and remove the (4) four 6mm screws.
    • Twist off the end cap and remove them from the device.
  4. JBL Charge 2 Motherboard Replacement: 手順 4、 2の画像 1 JBL Charge 2 Motherboard Replacement: 手順 4、 2の画像 2
    • Use a Phillips #1 screwdriver (PH1) to remove the (2) two screws from the battery cover.
    • Pry away the plastic battery cover with a plastic spudger.
  5. JBL Charge 2 Motherboard Replacement: 手順 5、 1の画像 1
    • Disconnect the battery connector with a plastic opening tool and wiggle the connector free.
  6. JBL Charge 2 Motherboard Replacement: 手順 6、 3の画像 1 JBL Charge 2 Motherboard Replacement: 手順 6、 3の画像 2 JBL Charge 2 Motherboard Replacement: 手順 6、 3の画像 3
    • Scrape the battery wire sealant off with a plastic opening tool, and ensure it is free of the body of the speaker and wires.
    • Slide the battery free.
  7. JBL Charge 2 Motherboard Replacement, Speakers: 手順 7、 1の画像 1
    • Remove the opposite screen cover using a metal spudger
  8. JBL Charge 2 Motherboard Replacement: 手順 8、 1の画像 1
    • Use the Phillips #1 screwdriver (PH1) to remove the (8) eight screws.
    • Pull out the speakers from the device.
  9. JBL Charge 2 Motherboard Replacement: 手順 9、 1の画像 1
    • Disconnect the wiring from the speaker by using the fine tip pry tool.
    • Remove the speakers from the device.
  10. JBL Charge 2 Motherboard Replacement, Motherboard: 手順 10、 1の画像 1
    • Use a spudger to disconnect the gold antenna connector from the main circuit board.
  11. JBL Charge 2 Motherboard Replacement: 手順 11、 1の画像 1
    • Disconnect the microphone connector using the plastic opening tool.
  12. JBL Charge 2 Motherboard Replacement: 手順 12、 1の画像 1
    • Use a plastic opening tool to disconnect the 3.5 mm headphone connector.
  13. JBL Charge 2 Motherboard Replacement: 手順 13、 1の画像 1
    • Disconnect micro-b connector with a plastic opening tool.
  14. JBL Charge 2 Motherboard Replacement: 手順 14、 1の画像 1
    • Remove the connector to the USB connector using a plastic opening tool.
  15. JBL Charge 2 Motherboard Replacement: 手順 15、 1の画像 1
    • Remove the speaker wires from the control panel by prying off with a plastic opening tool.
  16. JBL Charge 2 Motherboard Replacement: 手順 16、 1の画像 1
    • Next, disconnect the control-panel ribbon by prying out the grey plastic tab using a plastic opening tool. The ribbon should freely come out afterwards.
  17. JBL Charge 2 Motherboard Replacement: 手順 17、 3の画像 1 JBL Charge 2 Motherboard Replacement: 手順 17、 3の画像 2 JBL Charge 2 Motherboard Replacement: 手順 17、 3の画像 3
    • Caution: Touching the capacitors will short out the circuit board. Push on the end of the circuit board and carefully keep thumbs on foam insulation on ends of board.
    • Remove the motherboard from the device.
終わりに
5 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Mauzor Ilonzo
メンバー登録日: 09/26/17
495 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team S2-G4, Passmore Fall 2017 USF Tampa, Team S2-G4, Passmore Fall 2017人のメンバー
USFT-PASSMORE-F17S2G4
4 メンバー
8のガイドは作成済み
2 件のコメント
Guten Tag
Vielen Dank für die prima Anleitung!
Ich habe den Fehler bei meinem Charge 2+ gefunden. Das Bauteil mit der 100 drauf ist außen mehrfach gerissen. Was ist das für ein Bauteil und kann ich das bestellen?
Liebe Grüße
Stefan
Stefan Erb - 返信
Hello i have a problem with component 100 but i don't now what is ? someone can help me thanks and from were can i order ?
naskicha_94 - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 11
過去 30 日: 60
今までの合計 8,334
