メインコンテンツにスキップ
Itel 2163 Disassembly
必要な工具と部品
  1. Itel 2163 Disassembly, Switch off the phone: 手順 1、 2の画像 1 Itel 2163 Disassembly, Switch off the phone: 手順 1、 2の画像 2
    • First switch off the phone by longpressing the power button.
  2. Itel 2163 Disassembly, Remove Back Cover and Battery: 手順 2、 3の画像 1 Itel 2163 Disassembly, Remove Back Cover and Battery: 手順 2、 3の画像 2 Itel 2163 Disassembly, Remove Back Cover and Battery: 手順 2、 3の画像 3
    • Remove the back cover of the phone and the battery, then check for any available sim card(s), and eject the sim card(s) from the sim bed(s).
  3. Itel 2163 Disassembly, Unscrew the Nuts: 手順 3、 3の画像 1 Itel 2163 Disassembly, Unscrew the Nuts: 手順 3、 3の画像 2 Itel 2163 Disassembly, Unscrew the Nuts: 手順 3、 3の画像 3
    • Get the phillips #00 screwdriver and check for the available four (4) nuts/screws attaching the front and middle case together.
  4. Itel 2163 Disassembly, Pry the Phone open: 手順 4、 3の画像 1 Itel 2163 Disassembly, Pry the Phone open: 手順 4、 3の画像 2 Itel 2163 Disassembly, Pry the Phone open: 手順 4、 3の画像 3
    この手順で使用する道具:
    Plastic Cards
    $2.99
    購入する
    • Get a plastic card and slice open the phone at the rear end towards the charging port in order to separate the middle case (sim bed case) from the front case (screen case).
    • Do not pry the phone open with your finger, it is not safe and ethical as you can injure your finger nail in the process.
  5. Itel 2163 Disassembly, The Motherboard in view: 手順 5、 3の画像 1 Itel 2163 Disassembly, The Motherboard in view: 手順 5、 3の画像 2 Itel 2163 Disassembly, The Motherboard in view: 手順 5、 3の画像 3
    • After prying the phone open, you will then be left with the motherboard and screen in view. Attached to the motherboard, you'll see the charging port, the mic, the speaker, the earphone jack, etc.
    • Be careful with handling of the screen so as not to cause any defect to the screen flex thereby making the screen to malfunction or not work again.
終わりに
To reassemble this device, follow these instructions in reverse order.
7 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Aanuoluwapo Owoseeni
メンバー登録日: 04/28/22
397 ポイント
1ガイドが承認済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 25
過去 30 日: 99
今までの合計 1,923
