はじめに
This guide is about how to fix the jerking bump.
No parts need to be replaced.
必要な工具と部品
Fold backrest forward by pressing the release tab in and under the chair (Arrowed) and push the backrest forward.
On the two last pictures you can see the release lock and tap after the backrest is folded forward
Remove the screw for the cord inlet (Marked as 1) and remove the cord cover
Remove the 5 screws (marked 2) for the back cover - Please note they are NOT all the same size, so pay attention to the positions
With the cord cover (#1 in previous step) removed, remove the two connectors
The connectors on my model was protected with plastic strips to prevent me from releasing the lock tap - didn't work - I took the picture AFTER I had removed the cover so it was easier to see what the connectors looked like
Remove the strips or pull them towards the wires (Upwards) and use a flathead screwdriver to prise the lock open and remove the connector
Remove the back cover
In my case I looked at the mechanism and saw no immediate failures
I then noticed that a black strap (Arrowed) was showing signs of being curled/crumbled
Further examination shows that the strap, which goes from top to bottom, was not aligned 100 % centered between the massage wheels (I try to show that with the red line) and the strap had become a little loose
The result was the that the right wheel was sort of "picking up" the strap, so both wheels was on the same side of the strap
At some point the right massage wheel had to cross back again over the strap hereby crumbling it and giving this jerky bump.
The fix is to tighten the strap - there are two ways
1 - Remove the frame with wheels and rollers and re-align + tighten the strap
2 - Tighten and partly re-align the strap
I opted for solution 2
I tightened the strap at the botton of the frame, because this is where I had space to manouvre
I positioned the strap more to the left so it got centered
I used a 1.5 mm drill to prepare a whole in the frame so the plate screw (See picture 2) does not rapture the woodden frame
I used a plate screw to secure the strap in the new position
To reassemble your device, re-connect the cable connectors
Then place the back cover again, making sure it fits without pinching something
Finally place the cable/cord cover
