メインコンテンツにスキップ
Ion Air Pro Body Cover Replacement
必要な工具と部品
  1. Ion Air Pro Body Cover Replacement, Body Cover: 手順 1、 1の画像 1
    • Unscrew all six screws.
    • Make sure you put the screws in a good spot where you won't lose them because they are small.
  2. Ion Air Pro Body Cover Replacement: 手順 2、 1の画像 1
    • After you're done with unscrewing, take off the blue lid shown here.
  3. Ion Air Pro Body Cover Replacement: 手順 3、 1の画像 1
    • On the other side of the device, lift this black piece of cover that is underneath the cap, on the bottom side of the Ion Air Pro.
  4. Ion Air Pro Body Cover Replacement: 手順 4、 1の画像 1
    • After removing the black lid, unscrew all eight screws here.
    • Again, make sure you keep track of your screws and don't lose them.
  5. Ion Air Pro Body Cover Replacement: 手順 5、 1の画像 1
    • Remove two more screws, one on each side, inside this socket.
  6. Ion Air Pro Body Cover Replacement: 手順 6、 1の画像 1
    • Next, unscrew the two screws located here.
  7. Ion Air Pro Body Cover Replacement: 手順 7、 1の画像 1
    • Detach the bottom black piece off from the bottom side but do not disconnect it from the wires.
    • Everything inside is still connected with all the wires, so be careful not to pull too hard or else everything inside could fall out or get broken.
  8. Ion Air Pro Body Cover Replacement: 手順 8、 1の画像 1
    • Finally, you can remove the body cover off and replace it with a new one if you have to.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Christopher Brandl
メンバー登録日: 10/09/18
673 ポイント
5のガイドは作成済み
チーム
UW Stout, Team S6-G2, Ogden Fall 2018 UW Stout, Team S6-G2, Ogden Fall 2018人のメンバー
UWSTOUT-OGDEN-F18S6G2
4 メンバー
5のガイドは作成済み
4 件のコメント
Hey Chris where can I buy a replacement body cover?
The thread of the screw socket on my ion air pro WiFi has worn out and it can no longer be screwed onto any mounts.
Sam s - 返信
I LOST THE LOSTTHE REAR COVER WHILE HUNTING. iS THERE A REPLACEMENT I CAN GET
mcbee1010 - 返信
i lost the rear cover cap while hunting. can i purchase a new one
mcbee1010 - 返信
Can you show a photo of the other side (compared to step 8) showing the mounting thread please?
Andrew Mawby - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 8
今までの合計 630
