メインコンテンツにスキップ
Iomega Z100S2 Motherboard Replacement
必要な工具と部品
  1. Iomega Z100S2 Motherboard Replacement, Case: 手順 1、 2の画像 1 Iomega Z100S2 Motherboard Replacement, Case: 手順 1、 2の画像 2
    • Push in the plastic tab that can be seen through cracks in the front left corner using a spudger.
  2. Iomega Z100S2 Motherboard Replacement: 手順 2、 1の画像 1
    • Move down the same side and push in the plastic tab.
  3. Iomega Z100S2 Motherboard Replacement: 手順 3、 1の画像 1
    • Move to the front right side and once again push in the plastic tab.
    • There is not a fourth tab to push in after this one.
  4. Iomega Z100S2 Motherboard Replacement: 手順 4、 2の画像 1 Iomega Z100S2 Motherboard Replacement: 手順 4、 2の画像 2
    • Grab the cover by the front side and pull upwards.
    • You might encounter some resistance. Pull firmly, but don't yank it.
  5. Iomega Z100S2 Motherboard Replacement: 手順 5、 2の画像 1 Iomega Z100S2 Motherboard Replacement: 手順 5、 2の画像 2
    • Tilt the front case down until the pegs detach from the bottom of the case.
    • Lift up and outward.
    • The motherboard will be loose at this point.
  6. Iomega Z100S2 Motherboard Replacement, Disk Reader: 手順 6、 2の画像 1 Iomega Z100S2 Motherboard Replacement, Disk Reader: 手順 6、 2の画像 2
    • Unhook the two springs from the front plastic hooks.
    • The black side rails of the reader should easily slide forward and off.
  7. Iomega Z100S2 Motherboard Replacement: 手順 7、 1の画像 1
    • There is a white tab connected to the motherboard. Pull it upward by gently rocking it back and forth.
    • The tab does not come completely out, it only slides up slightly, so don't rip it out!
  8. Iomega Z100S2 Motherboard Replacement: 手順 8、 2の画像 1 Iomega Z100S2 Motherboard Replacement: 手順 8、 2の画像 2
    • Grab the reader by its sides and gently pull it upward.
    • There are two wires still connected to the bottom of the reader that haven't been detached.
  9. Iomega Z100S2 Motherboard Replacement: 手順 9、 1の画像 1
    • Disconnect the white wires by using tweezers to gently pull the bottom connector toward you.
  10. Iomega Z100S2 Motherboard Replacement: 手順 10、 2の画像 1 Iomega Z100S2 Motherboard Replacement: 手順 10、 2の画像 2
    • Disconnect the thin ribbon wire by using tweezers to gently pull the connector at the bottom toward you.
  11. Iomega Z100S2 Motherboard Replacement: 手順 11、 1の画像 1
    • Lift the reader up and out from the device.
  12. Iomega Z100S2 Motherboard Replacement, Motherboard: 手順 12、 2の画像 1 Iomega Z100S2 Motherboard Replacement, Motherboard: 手順 12、 2の画像 2
    • Use a T6 Torx Screwdriver to remove the 1.3 mm screw at the back of the motherboard.
  13. Iomega Z100S2 Motherboard Replacement: 手順 13、 2の画像 1 Iomega Z100S2 Motherboard Replacement: 手順 13、 2の画像 2
    • Gently lift the motherboard and back case out from the bottom case.
終わりに
作成者
3人の作成者と共同で作成されました。
Ezery Kennedy
メンバー登録日: 10/05/10
288 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 7-53, Amido Fall 2010 Cal Poly, Team 7-53, Amido Fall 2010人のメンバー
CPSU-AMIDO-F10S7G53
4 メンバー
6のガイドは作成済み
コメント 1 件
how to fix the motherboard if booth leds stay lit when powering up?
ACIDGREEN TECHNO - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 3,426
