メインコンテンツにスキップ
International Scout 80 Clutch replacement
必要な工具と部品
  1. International Scout 80 Clutch replacement, Clutch: 手順 1、 1の画像 1
    • Start with removing passenger seat. Remove shifter boots and shift knobs. Next the center transmission/transfer case cover inside the vehicle.
  2. International Scout 80 Clutch replacement: 手順 2、 2の画像 1 International Scout 80 Clutch replacement: 手順 2、 2の画像 2
    • Next you'll need an impact gun or a large 1/2 inch drive breaker bar to remove the nut from inside the transfer case. It is behind the round cover on the transfer case. You should also remove the speedometer cable from the transfer case. This would be a good time to disconnect the drivelines, wrap tape around the U-joints to keep the caps from falling off and losing the needle bearings. I use pieces of coat hanger to hang the drive lines.
  3. International Scout 80 Clutch replacement: 手順 3、 1の画像 1
    • To drain the fluid there are drain plugs on the transmission and transfer case, I still had quite a bit of oil in my transmission so you may get a mess when separating the units. There is a bolt that goes in from the front of the transmission into the transfer case, just to passenger side be sure to remove it.The two may be removed as a single unit but it's harder to maneuver it out of the hole and much heavier. ( or if you have the equipment you can drop it under after removing the shifters)
終わりに
9 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
junkemails70
メンバー登録日: 05/27/10
279 ポイント
1ガイドが承認済み
2 件のコメント
How do you adjust a hydroelectric clutch
josh helgeson - 返信
In most cases, the  clutch replacement  will involve replacing the clutch disc, releasing the pilot bearing, and replacing or resurfacing the flywheel.
5stars auto parts - 返信
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 31
過去 30 日: 152
今までの合計 8,063
