メインコンテンツにスキップ
Interlink VP4550 Circuit Board Replacement
必要な工具と部品
  1. Interlink VP4550 Circuit Board Replacement, Case: 手順 1、 3の画像 1 Interlink VP4550 Circuit Board Replacement, Case: 手順 1、 3の画像 2 Interlink VP4550 Circuit Board Replacement, Case: 手順 1、 3の画像 3
    • Turn the phone over to where the battery compartment resides.
    • Remove the battery compartment door by pushing down on the door with your thumbs and sliding the door off of the bottom of the device.
    • Remove battery.
  2. Interlink VP4550 Circuit Board Replacement: 手順 2、 3の画像 1 Interlink VP4550 Circuit Board Replacement: 手順 2、 3の画像 2 Interlink VP4550 Circuit Board Replacement: 手順 2、 3の画像 3
    • Use a Phillips #0 screwdriver to remove the screw in the middle of the battery compartment.
    • Pry open the case body with the plastic opening tool. Start at the bottom of the device and work toward the top. You will hear a "click" sound as the sides open.
  3. Interlink VP4550 Circuit Board Replacement: 手順 3、 2の画像 1 Interlink VP4550 Circuit Board Replacement: 手順 3、 2の画像 2
    • There is a wire connector linking the front and the back of the device.
    • Carefully pull the wire connectors out of the white connector gauge to completely separate the front and back pieces.
  4. Interlink VP4550 Circuit Board Replacement: 手順 4、 2の画像 1 Interlink VP4550 Circuit Board Replacement: 手順 4、 2の画像 2
    • The power button may fall off when you separate the front and back of the device. This can simply be placed back when reassembling.
    • Find the lever on the right side of the back half of the device.
    • Insert the tip of the lever into the square indent on the underside of the button.
  5. Interlink VP4550 Circuit Board Replacement, Circuit Board: 手順 5、 1の画像 1
    • Avoid picking up the front of the device as you work so that loose parts will not shift.
    • Use a Phillips #0 head screwdriver to remove two screws; one on either side of the circuit board.
  6. Interlink VP4550 Circuit Board Replacement: 手順 6、 1の画像 1
    この手順で使用する道具:
    • Slide the circuit board down from the tab located underneath the top of the back half
    • The laser is attached to the circuit board and will slide out of its own housing as you slide out the circuit board.
    • Use tweezers to gently remove it if it doesn't come out.
終わりに
作成者
12人の作成者と共同で作成されました。
custer78
メンバー登録日: 02/11/14
24 ポイント
1ガイドが承認済み
チーム
Ohio State, Team 1-1, Buehl Spring 2014 Ohio State, Team 1-1, Buehl Spring 2014人のメンバー
OSU-BUEHL-S14S1G1
4 メンバー
3のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 14
今までの合計 293
