メインコンテンツにスキップ
Inter-tel IP 8660 Motherboard Replacement
必要な工具と部品
  1. Inter-tel IP 8660 Motherboard Replacement, Rear Cover: 手順 1、 1の画像 1
    • Before disassembling the phone, make sure it is not plugged into power and the handset phone cord is disconnected from the handset jack.
  2. Inter-tel IP 8660 Motherboard Replacement: 手順 2、 3の画像 1 Inter-tel IP 8660 Motherboard Replacement: 手順 2、 3の画像 2 Inter-tel IP 8660 Motherboard Replacement: 手順 2、 3の画像 3
    • Unscrew the 9 highlighted screws using a #1 Phillips head screwdriver. You can use a magnetized screwdriver to draw them out.
    • 8 mm long
    • 11 mm long
  3. Inter-tel IP 8660 Motherboard Replacement: 手順 3、 1の画像 1
    • Lift up the back cover and set it aside.
  4. Inter-tel IP 8660 Motherboard Replacement, Internal speaker: 手順 4、 1の画像 1
    • While holding down the motherboard, gently pull the wire harness connecting the speaker to the motherboard until it comes free.
  5. Inter-tel IP 8660 Motherboard Replacement: 手順 5、 1の画像 1
    • Lift up the speaker.
  6. Inter-tel IP 8660 Motherboard Replacement, LCD Screen: 手順 6、 3の画像 1 Inter-tel IP 8660 Motherboard Replacement, LCD Screen: 手順 6、 3の画像 2 Inter-tel IP 8660 Motherboard Replacement, LCD Screen: 手順 6、 3の画像 3
    • Lift up the motherboard out of its housing in the front cover of the phone.
    • Set the front cover and button pads aside.
  7. Inter-tel IP 8660 Motherboard Replacement: 手順 7、 3の画像 1 Inter-tel IP 8660 Motherboard Replacement: 手順 7、 3の画像 2 Inter-tel IP 8660 Motherboard Replacement: 手順 7、 3の画像 3
    • Using tweezers, pinch the highlighted connective clips together and depress. Start with the clips in the middle of the motherboard first.
    • Note: There are four clips, one at each corner of the LCD screen.
  8. Inter-tel IP 8660 Motherboard Replacement: 手順 8、 1の画像 1
    • Flip the motherboard over so that the LCD screen is facing upward.
  9. Inter-tel IP 8660 Motherboard Replacement: 手順 9、 2の画像 1 Inter-tel IP 8660 Motherboard Replacement: 手順 9、 2の画像 2
    • Push the black clip holding the ribbon cable out of its casing using the plastic opening tool.
    • This is done using the spudger to lift one side out of its housing.
    • Reposition the spudger to the other side of the black clip and push it flush with the other end.
    • Note: The black clip pushes out of the housing and does not come completely loose.
  10. Inter-tel IP 8660 Motherboard Replacement: 手順 10、 3の画像 1 Inter-tel IP 8660 Motherboard Replacement: 手順 10、 3の画像 2 Inter-tel IP 8660 Motherboard Replacement: 手順 10、 3の画像 3
    • Pull gently on the ribbon cable so that it comes loose from the black clip.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Mariano Bautista
メンバー登録日: 01/20/12
16 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 11-24, Maness Winter 2012 Cal Poly, Team 11-24, Maness Winter 2012人のメンバー
CPSU-MANESS-W12S11G24
4 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 3
今までの合計 1,104
