メインコンテンツにスキップ
Inter-tel IP 8660 Handset Microphone and Receiver. Replacement
必要な工具と部品
  1. Inter-tel IP 8660 Handset Microphone and Receiver. Replacement, Handset Back Cover: 手順 1、 1の画像 1
    • Disconnect the phone cord from the handset jack.
  2. Inter-tel IP 8660 Handset Microphone and Receiver. Replacement: 手順 2、 2の画像 1 Inter-tel IP 8660 Handset Microphone and Receiver. Replacement: 手順 2、 2の画像 2
    • Unscrew the two black screws (8 mm long) located in the middle of the handset using #1 Phillips head.
  3. Inter-tel IP 8660 Handset Microphone and Receiver. Replacement: 手順 3、 2の画像 1 Inter-tel IP 8660 Handset Microphone and Receiver. Replacement: 手順 3、 2の画像 2
    • Pry the back cover off the headset using a spudger. It is best to pry at the top of the handset.
  4. Inter-tel IP 8660 Handset Microphone and Receiver. Replacement, Handset Microphone and Receiver.: 手順 4、 1の画像 1
    • While holding the handset front cover, grasp and twist the handset microphone and jack until they come free from the cover.
  5. Inter-tel IP 8660 Handset Microphone and Receiver. Replacement: 手順 5、 3の画像 1 Inter-tel IP 8660 Handset Microphone and Receiver. Replacement: 手順 5、 3の画像 2 Inter-tel IP 8660 Handset Microphone and Receiver. Replacement: 手順 5、 3の画像 3
    • Unscrew the 2 screws (8 mm long) that hold the receiver in place using a #1 Phillips screwdriver.
    • Note: The screws come with washers.
  6. Inter-tel IP 8660 Handset Microphone and Receiver. Replacement: 手順 6、 2の画像 1 Inter-tel IP 8660 Handset Microphone and Receiver. Replacement: 手順 6、 2の画像 2
    • Pull the red and green wires that connect the receiver to the microphone out from under the metal piece and black padding.
    • Note: To insert the wires back underneath the black padding, pull the black padding back with your finger and use plastic opening tool to wedge the wires underneath the black padding.
終わりに
作成者
4人の作成者と共同で作成されました。
Juan David GutierrezFranco
メンバー登録日: 01/20/12
67 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 11-24, Maness Winter 2012 Cal Poly, Team 11-24, Maness Winter 2012人のメンバー
CPSU-MANESS-W12S11G24
4 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 11
今までの合計 975
