メインコンテンツにスキップ
Instant Pot IP-DUO80 V2 LED Display Replacement
必要な工具と部品
  1. Instant Pot IP-DUO80 V2 LED Display Replacement, LED Display: 手順 1、 3の画像 1 Instant Pot IP-DUO80 V2 LED Display Replacement, LED Display: 手順 1、 3の画像 2 Instant Pot IP-DUO80 V2 LED Display Replacement, LED Display: 手順 1、 3の画像 3
    • Open the lid by turning it counter-clockwise and lifting up.
    • Remove the inner pot.
  2. Instant Pot IP-DUO80 V2 LED Display Replacement: 手順 2、 3の画像 1 Instant Pot IP-DUO80 V2 LED Display Replacement: 手順 2、 3の画像 2 Instant Pot IP-DUO80 V2 LED Display Replacement: 手順 2、 3の画像 3
    • Turn the Instant Pot upside down.
    • Remove the single 12-mm screw by using the T-15 head screwdriver and turning it counter-clockwise.
    • Turn the plate counter-clockwise and lift it off the Instant Pot.
  3. Instant Pot IP-DUO80 V2 LED Display Replacement: 手順 3、 2の画像 1 Instant Pot IP-DUO80 V2 LED Display Replacement: 手順 3、 2の画像 2
    • Remove the three 19-mm screws in the black plastic base's edge using the PH-1 head screwdriver and twisting counter-clockwise.
  4. Instant Pot IP-DUO80 V2 LED Display Replacement: 手順 4、 2の画像 1 Instant Pot IP-DUO80 V2 LED Display Replacement: 手順 4、 2の画像 2
    • Pull the power cord out of its slot.
    • Pull up on the edge of the black plastic base to remove the base.
  5. Instant Pot IP-DUO80 V2 LED Display Replacement: 手順 5、 3の画像 1 Instant Pot IP-DUO80 V2 LED Display Replacement: 手順 5、 3の画像 2 Instant Pot IP-DUO80 V2 LED Display Replacement: 手順 5、 3の画像 3
    • Disconnect the two green-striped yellow wires that are connected onto the bottom of the heating element. Use a PH-1 head screwdriver and turn counter-clockwise to remove the 10-mm screw holding them in place.
    • Be careful not to lose the small washer that comes with this screw.
    • Pull up on the cn101 connection to detach the LED display from the motherboard.
  6. Instant Pot IP-DUO80 V2 LED Display Replacement: 手順 6、 1の画像 1
    • Lift the silver outer shell off of the top black ring.
  7. Instant Pot IP-DUO80 V2 LED Display Replacement: 手順 7、 3の画像 1 Instant Pot IP-DUO80 V2 LED Display Replacement: 手順 7、 3の画像 2 Instant Pot IP-DUO80 V2 LED Display Replacement: 手順 7、 3の画像 3
    • Remove the two 10-mm screws connecting the LED display to the outer shell using a PH-1 head screwdriver and twisting counter clockwise.
    • Pull out the LED display by pulling on it gently.
終わりに
6 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Kayla Meacham
メンバー登録日: 01/23/18
630 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team S18-G2, Livingston Winter 2018 Cal Poly, Team S18-G2, Livingston Winter 2018人のメンバー
CPSU-LIVINGSTON-W18S18G2
4 メンバー
10のガイドは作成済み
2 件のコメント
Where can I get the replacement for the display?
Starfish Doodle - 返信
Hola disculpa, donde puedo conseguir la pantalla led de mi instat pot DUO PLUS MULTI-COOKER 9in 1
Evaristo - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 74
今までの合計 6,456
