メインコンテンツにスキップ
Instant Pot 60 EPC Pressure Sensor Replacement
必要な工具と部品
  1. Instant Pot 60 EPC Pressure Sensor Replacement, Pressure Sensor: 手順 1、 3の画像 1 Instant Pot 60 EPC Pressure Sensor Replacement, Pressure Sensor: 手順 1、 3の画像 2 Instant Pot 60 EPC Pressure Sensor Replacement, Pressure Sensor: 手順 1、 3の画像 3
    • Ensure the device is unplugged and cool before beginning.
    • Remove the lid and inner pot from the Instant Pot and turn the body upside down.
    • Remove the single Torx screw.
  2. Instant Pot 60 EPC Pressure Sensor Replacement: 手順 2、 2の画像 1 Instant Pot 60 EPC Pressure Sensor Replacement: 手順 2、 2の画像 2
    • Turn the bottom face counterclockwise and remove it.
  3. Instant Pot 60 EPC Pressure Sensor Replacement: 手順 3、 3の画像 1 Instant Pot 60 EPC Pressure Sensor Replacement: 手順 3、 3の画像 2 Instant Pot 60 EPC Pressure Sensor Replacement: 手順 3、 3の画像 3
    • In order to reach the pressure sensor you'll need to remove the secondary frame.
    • Remove the three Phillips screws securing the frame.
    • Lift the frame, twist and set next to the body. Take care not to damage any of the attached wiring.
    • Locate the sensor. It has been highlighted in the final image.
  4. Instant Pot 60 EPC Pressure Sensor Replacement: 手順 4、 2の画像 1 Instant Pot 60 EPC Pressure Sensor Replacement: 手順 4、 2の画像 2
    • To remove the sensor, unscrew the main screw between the sensor and slide out.
  5. Instant Pot 60 EPC Pressure Sensor Replacement: 手順 5、 3の画像 1 Instant Pot 60 EPC Pressure Sensor Replacement: 手順 5、 3の画像 2 Instant Pot 60 EPC Pressure Sensor Replacement: 手順 5、 3の画像 3
    • To remove the leads connecting the sensor to the motherboard you will need to unclip them.
    • In order to do so, slide the blue covering up to expose the small hole in the lead.
    • Place a SIM card punch into the hole to unsecure the leads and pull them up. If a SIM card punch is not avaliable then a paperclip or earring should suffice.
  6. Instant Pot 60 EPC Pressure Sensor Replacement: 手順 6、 2の画像 1 Instant Pot 60 EPC Pressure Sensor Replacement: 手順 6、 2の画像 2
    • There will be a secondary lead that is black connecting the sensor the the motherboard.
    • In order to remove that lead just squeeze and pull up.
  7. Instant Pot 60 EPC Pressure Sensor Replacement: 手順 7、 1の画像 1
    • Instant Pot does not provide a new sensor with the device, so it will have to be purchased from a secondary source.
終わりに
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Bela Hernandez
メンバー登録日: 08/28/24
998 ポイント
5のガイドは作成済み
チーム
University of North Texas, Team 6-4, Kilpatrick Fall 2024 University of North Texas, Team 6-4, Kilpatrick Fall 2024人のメンバー
UNT-KILPATRICK-F24S6G4
4 メンバー
5のガイドは作成済み
1件のガイドコメント
My pro plus comes with only one sensor. Where can I find it's replacement?
Dr. Khalid S - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 64
今までの合計 540
