はじめに
How to properly install bObi's battery after initial purchase or in case of replacement.
パーツ
パーツは指定されていません。
  1. Use a phillips head screwdriver to remove the two screws holding the battery cover down. Lift the battery cover up. Lift the battery cover up.
    • Use a phillips head screwdriver to remove the two screws holding the battery cover down.
    • Lift the battery cover up.
  2. MacBook Battery 修理キット
    最低価格 $69.99
    Buy Now
    最低価格 $69.99
    Buy Now
  3. Plug in the battery's circuit plug. Lower the battery into bObi. Tuck the wire into the side of the battery. do not push it underneath the battery itself.
    • Plug in the battery's circuit plug.
    • Lower the battery into bObi.
    • Tuck the wire into the side of the battery. do not push it underneath the battery itself.
  4. When both are lowered into the compartment, replace the battery cover. Ensure it lies flat overtop the battery. Reinstall the two screws to finish assembling bObi's battery. Reinstall the two screws to finish assembling bObi's battery.
    • When both are lowered into the compartment, replace the battery cover. Ensure it lies flat overtop the battery.
    • Reinstall the two screws to finish assembling bObi's battery.
ゴール
ある他の人がこのガイドを完成しました。
Chelsea
メンバー登録日: 2014年09月24日
2,278 ポイント
31のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 513
