はじめに
A bobbin is a small spool of thread that feeds the thread for the backside of the stitch. No sewing machine can sew without one. An incorrectly set up bobbin will create tangles in the thread. Bobbin setups vary from machine to machine. This guide shows the process for a Bernina 830, but the process will be similar for most sewing machines, except for those with drop-in bobbins. Refer to your sewing machine’s owner’s manual for specific directions on how to install a bobbin in your machine.
必要な工具と部品
Align the hole in the bobbin spindle over the peg in the bobbin case.
Slide the bobbin into the bobbin case, leaving a bit of thread outside the case.
Take the loose thread end and slide it through the slit on the side of the bobbin case.
5 の人々がこのガイドを完成させました。
