はじめに
There are many benefits to adding a second hard drive to your laptop such as improved speeds, greater storage space, and less heartache when installing new software. Use this guide to install one using our optical bay hard drive enclosure.
必要な工具と部品
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm (14.1 mm) Phillips screws.
Seven 3 mm Phillips screws.
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Pull the optical drive cable out of the optical drive.
Remove the two black Phillips #0 screws securing the small metal mounting bracket. Transfer this bracket to your new optical drive or hard drive enclosure.
Remove the plastic spacer from the optical bay hard drive enclosure by pressing in on one of the clips on either side and lifting it up and out of the enclosure.
Make sure that the hard drive connectors are facing down before placing it into the enclosure.
Gently place the hard drive into the enclosure's hard drive slot.
While firmly holding the enclosure in place with one hand, use your other hand to press the hard drive into the enclosure connectors.
138 の人々がこのガイドを完成させました。
10 件のコメント
I have a Macbook Pro 15″ (late 2011) running OS Sierra with 128GB SSD in the main bay and a 1TB Toshiba MQ01ABD100 HDD Sata II (3Gb/s) in the optical bay. Both formated as Mac OS Extended Journaled. OS and apps are running fine from the SSD, however the HDD is behaving odd: I can’t write anything on it, even when permissions say “anyone can read and write”. I got error code -50. Sometimes, the drive icon takes a while to appear in my desktop. I already:
– Replaced the optical drive flex cable.
– Tested the HDD as external drive via USB connection. (It works)
– Relaunched the finder.
– Reset SMC and PRAM.
As the optical drive was “out of service” long before I made the dual drive setup, I begun to think it might be a problem with the computer hardware itself, but then I remembered my logic board was replaced by Apple only few months ago. And a friend told me he succesfully did the dual setup regardless his optical drive wasn’t working.
I don’t know what else to try. Help!
I have same Macbook Pro 15" late 2011 with similar setup and the same problem. Unfortunately I haven't found the solution yet... :(
Rafal -
Very similar problem here!
Macbook Pro13" late 2011 (8.1)
I removed the optical driver some years ago moving in it the HDD and using as my main system drive an SSD.
Now the HDD in the optical bay is very slow, repairing it with disk utility didn't resolve the problem.
I read similar stories solved replacing the cable. Some one solved in that way?
